New ddp stage 2 injectors , one leaking , help
Old 09-10-2011, 04:00 PM
SKATERHAULER's Avatar
Spent a week installing new head gaskit , ARP studs and DDP stage 2 injectors , started it up no leaks , went for a ride and noticed number 1 injector was leaking . I loosened the line nut then tightened , removed return line sealing washer and re-intalled , still leaks , removed number 1 and 2 injector and swapped out , and it now leaks @ # 2 . Upon removal I checked to make sure injector itself was tightened together and it was tight , and thoughts ?
Larry
Old 09-10-2011, 04:04 PM
Lil Dog's Avatar
Its leaking from the injector body to the high pressure line right? I had mine leak from the return line and needed to really clean the tubing connection and copper "U" washer.
I would just take some fine emery and clean the injector end and tubing. its a compression fit so also make sure all the threads on the injector are clean and straight, it could be binding before its tight.
After all that call DDP..
Old 09-10-2011, 04:07 PM
To be honest I dont think the leak is fron the HP line , as mentioned it was orig put in # 1 where it leaked and now its in # 2 and still leaking . It appears to work up the threads
Old 09-10-2011, 04:13 PM
Lil Dog's Avatar
So is it leaking fuel or compression??
Old 09-10-2011, 04:17 PM
Sorry , fuel ! Comp would be a no brainer to figure out
Old 09-10-2011, 06:05 PM
Lil Dog's Avatar
I would pull the return line off again and polish the washer and injector body.. I had to do mine twice to get it to stop leaking.
Old 09-10-2011, 09:47 PM
Very good tip , I will try that on Sun 9-11-11
Old 09-12-2011, 01:33 PM
Well I removed the injector with leaking fuel issue which was in # 2 hole , polished the area where the return line goes on and moved it to # 3 hole and installed 3 new sealing washers for 1 -3 hole . Fired it up and I now have a fuel leak on # 3 and it is pretty clear that it the injector itself and only leaks after a few minutes and gets hot . Lenny @ DDP said it is very rare to have this issue , however it does happen every once in a while and is over-nighting me an injector . Anyone else had this issue ?
Old 09-12-2011, 02:15 PM
Lil Dog's Avatar
Well you did everything I can think off. Lenny is a good guy to deal with.
Old 09-12-2011, 03:08 PM
Did your trick , polished exit port area with # 400 to remove maching grooves and still leaks . My 35 yrs from Dirt bikes to my offshore race boats I have always had one off problems that nobody else ever has !!
Larry
BurrisWill
04-01-2009 07:16 PM
relay93
03-13-2007 11:25 PM
98.5POS
19
02-07-2007 09:22 AM
silverbullet02
04-24-2006 04:08 PM
fishin fever
03-23-2006 02:04 AM
Quick Reply: New ddp stage 2 injectors , one leaking , help
