Negative detonation temp?
Old 03-14-2006, 07:44 AM
slimpicken's Avatar
Question Negative detonation temp?
What is the negative detonation temp for a diesel motor? When does fuel wash start to occur?
Old 03-14-2006, 02:20 PM
TexasCTD's Avatar
Good question. Does anybody know?
Old 03-14-2006, 02:59 PM
Herrin811's Avatar
Im guessing cylinder temp below 141'F
Old 03-14-2006, 09:03 PM
slimpicken's Avatar
thats a pretty interesting "guess" exactly 141 . Is that really an guess or an educated estimation?
Old 03-15-2006, 06:50 AM
cad14man's Avatar
I have read on other boards that the ECM will raise the RPM of the engine whenever it is below 175 to prevent cylinder washing from happening....so my guess is 141 ~ 175 or less
Old 03-16-2006, 06:51 AM
slimpicken's Avatar
thanks I had been wondering that cause mine will idle at around 220* when its in the seventies and have seen it as low as 185 when it was in the teens with a warm motor.
On a side note, my digital guage seems really accurate and instant cause it will show you the temp change almost by cylinder as it idles. Ok probably not but it does show every revolution the motor makes, you can see every time it hits the dead spot in the motor and temp drops.
Old 03-16-2006, 09:00 AM
Herrin811's Avatar
Educated Estimate
Diesel fuel is listed as a combustible liquid....Combustbile liquids have a flash point above 141' F...Gasoline on the other hand is a flammble liquid, flammables have a flash point between 99-140'F...Extremely flammable liquids (ether) have flash points below 99'F
End of Haz-Mat Tech A...Any questions??
Old 03-16-2006, 08:33 PM
bigblock2stroke's Avatar
you have a problem if your coolant temp is at 220 at idle, even if it was 115 outside.
Old 03-17-2006, 09:25 AM
05mxdiesel's Avatar
I think he is talking about his egt guage. Mine on a cold motor is around 240.
northernwheeler
11-05-2008 07:23 PM
satburn
12-25-2006 02:31 PM
spunbearing
11-04-2006 06:21 PM
Flashpoint
04-10-2006 08:38 PM
dimarcoda
09-24-2004 01:10 PM
Quick Reply: Negative detonation temp?
