need more wine ???turbo ?
Old Jul 17, 2006 | 05:55 PM
loco one's Avatar
I want my turbo to sing to me ? I have a 92 ctd 14 gated turbo ( hot side )
works great ! my ? how can I get more wine from my cold side turbo ?
do I need to change that turbo (cold side ) which one ? will IT just bolt in ? also can somebody
educate me about turbo lingo ?? I have a ( hot side) h1c 14 gated turbo ? what is the cold side called ? what is a 35 ?
thanks loco one
Old Jul 17, 2006 | 06:05 PM
bgilbert's Avatar
Smooth intake and BHAF, ditch the ribbed factory intake hose and filter. You'll hear it sing more.
Old Jul 17, 2006 | 08:16 PM
gman07's Avatar
What bgilbert said, plus an HTT compressor housing/wheel upgrade and you'll get a nice whistle.
To educate you on turbo "lingo": you have an H1C with a 14cm exhaust housing. Most guys would write this in their signature as something like H1C/14WG. A "35" is simply an HX35. If you went with a 60mm compressor wheel from HTT, your cold side would turn into an H1C/H1E hybrid turbo. Same with HX35/40 hybrids. Hope this helps.
Old Jul 18, 2006 | 07:47 PM
loco one's Avatar
thanks guys
bgilbert, thanks ,I got rid of the stock ribbed intake hose today ! got my BHAF ,& A SMOOTH intake hose now ! I was supprised about that upgrade !
GMAN ,LOOKS LIKE I"ll be calling HTT soon you think a 60 mm is the way to go ? boost ? also your sig says 1400* is that e.g.t. ? why so hot ?1500 & your tost !! thanks for the lingo info !!
Old Jul 18, 2006 | 09:02 PM
gman07's Avatar
I personally would go with a 60mm. It will spool slower, but if you have the pump turned up it shouldn't be too bad. The stage II will also give you the whistle, but the Stage III will flow more (if you need that). The Stage IV is also a 60mm wheel and flows about 10% more than the Stage III due to its 6 blade design. The compressor upgrades won't necessarily add much boost, but they'll provide it more efficiently. It probably isn't necessary unless you're getting ~30psi.
On my truck EGT's are high because of too much fuel and not enough air (I'm looking at an HTT Stage III or IV soon also) combined with the 12cm housing.
Old Jul 19, 2006 | 11:45 AM
Falcon1's Avatar
So a 60mm wheel 6 blade will flow more air than my stock wheel? How hard is it to change out the wheel?
Greg
Old Jul 19, 2006 | 02:25 PM
gman07's Avatar
Yep, I think the Stage II is 58mm, 8 blade, Stage III is 60mm, 8 blade, and Stage IV is 60mm, 6 blade. The stage II and III are $200, the stage IV is $285. On the Stage II and III, it's just pull the compressor housing off, put a socket on the turbine side of the shaft, take the nut off the compressor side (REVERSE THREADS) , replace the wheel, and put everything back. The Stage IV requires taking the backing plate off to replace it with the one HTT sends.
Oh, these upgrades probably are only necessary if you have high EGT's or want a better sounding turbo.
Old Jul 19, 2006 | 06:36 PM
Forrest Nearing's Avatar
put an HX35 in there, it'll scream way louder than that non-MWE compressor housing you've got on there now.
endurancerider
Jul 13, 2011 08:32 AM
svanni
Dec 19, 2006 10:42 AM
tool
Dec 18, 2006 02:30 PM
zmock8
13
Jan 29, 2005 12:11 AM
CRT
Jul 11, 2004 04:52 PM
