muffler install question
Old 11-21-2009, 08:11 PM
firedoger's Avatar
I have a MBRP muffler and I'm wondering how folks are getting them installed ? The factory muffler has an offset between the front and the rear. The MBRP won't just mount to the piping. Did anyone have to weld hangers to their muffler ? Which way is the correct flow for an MBRP.
Old 11-23-2009, 11:21 AM
SnowRider1's Avatar
offset pipe
When I purchased my Aero, the place that I had ordered from also sold an offset pipe to make the connection work. I would have to do some searching, but I am sure I could find out where I got it if you need to know. And, the muffler should have an arrow or the word "flow" with an arrow on it, or one end should be expanded to fit over your current exhaust pipe.
Old 11-23-2009, 11:52 AM
AH64ID's Avatar
I used a muffler delete pipe and put the Donaldson 40" up where the cat was.
Old 11-23-2009, 12:14 PM
jimbo486's Avatar
most exhaust manufacturer's muffler or cat delete pipes have an offset for that reason.
Old 11-23-2009, 03:48 PM
MTC
MTC's Avatar
My MBRP muffler came with the offset pipe in the box. The little "nubs" inside need to be pointing open ends towards the back...
Old 11-23-2009, 08:09 PM
firedoger's Avatar
Thx for the reply's. I bought the muffler second hand for $50 bucks. There are no hangers attached to it. Do they come with hangers or does it not need them ? Any info as to where I can get an off set adaptor would be helpful.
Old 11-24-2009, 09:39 AM
Clane's Avatar
I like that idea.
Old 11-24-2009, 10:13 AM
05CTDN8's Avatar
I just got a piece of 4" stainless, cut the cat and muffler out and welded the pipe in their place....sweet!
Old 11-24-2009, 04:19 PM
2003Ram's Avatar
I set mine up with two 4" x 45's for the off-set and tucked the muffler up as high as it could go. Had to weld hangers to it as well.
timk006
10-13-2006 03:49 PM
Jmac
09-09-2006 10:23 PM
Patrick Campbell
03-23-2005 01:29 PM
commonrail
10-22-2004 07:47 PM
w4xtc
24
05-05-2003 04:36 PM
Quick Reply: muffler install question
