Manual trans and starting
Old 05-12-2008, 05:43 PM
riddle family's Avatar
How many of you guys start in second gear with a 6 speed manual tranny? Should I start in first gear all the time? The only time I do is when I am pulling the Fiver.
Old 05-12-2008, 06:01 PM
matt ellerbee's Avatar
im always starting in second, like you said unless im pulling a trailer, and even then it depends..
only time i use first is in traffic, just let it out and idle...
Old 05-12-2008, 06:05 PM
snoyes's Avatar
Most of starts with the stock clutch were in second, with the SBC DD i'm about 50/50 on first and second gear starts. Obviously, pulling a trailer, i always start in first.
Old 05-12-2008, 06:27 PM
chipmonk's Avatar
stock clutch, no load- 2nd gear.
Old 05-12-2008, 06:45 PM
mtl0727's Avatar
x2 on no load 2nd gear start
Old 05-12-2008, 10:18 PM
ZachMI2003's Avatar
2nd gear with no load, first is good for crawling trafic too
Old 05-12-2008, 11:14 PM
cgmorgan06's Avatar
X2........
Old 05-12-2008, 11:18 PM
rockcrawler304's Avatar
x3
I even started in 3rd a few times when just barely rolling. Mostly by accident though
Old 05-13-2008, 04:19 AM
MikesB12's Avatar
Same here......1st is too low when empty
Old 05-13-2008, 06:34 AM
Jason_K's Avatar
i agree with everyone else, with a stock clutch i always started in 2nd and sometimes 3rd if i was on a down grade.
Old 05-13-2008, 07:00 AM
MikeyB's Avatar
2nd gear for non or light towing. 1st for the heavier stuff.
MikeyB
Old 05-13-2008, 08:40 AM
carl48's Avatar
i drive enough of the 13-15=18-and 20 speed that i allways start off in first but there is no need 2nd is fine
Muted User
Sprinter17's Avatar
2ND for me too, and sometimes I shift 2-4-6 ,and just wind it to about 1800rpms so as not to lug it. Dodge manual says not too skip gears, but I've shifting trucks since the author was in diapers.
Old 05-13-2008, 08:41 AM
Valv's Avatar
When empty my shifting pattern is: 2nd start, 3rd, 5th, 6th, sometimes if I forget to got to 5th I shift from 4th to 6th.
Free89W350
12-28-2011 11:18 AM
RED99CTD
04-20-2011 08:08 AM
badzj999
08-20-2010 05:17 PM
abc4yew
03-15-2007 11:55 PM
djgaston
10-30-2005 03:18 PM
Quick Reply: Manual trans and starting
