Maintenance
Old 04-08-2007, 03:26 PM
DodgeDawg2500's Avatar
Maintenance
Alright,
I have had this truck for 3 years now, and am wondering what else I can do to make it run for a good long time. Truck has 86,699 miles.
I have changed the fluid in all of the following:
Differentials, transfer case, transmission, power steering, brake system.
I change the oil at the 7,500 mile interval and empty puke bottle;
fuel filter ~15,000 unless I get a bad batch of fuel or mileage goes down.
Stock airbox with stock filter, change as needed or 15,000 miles.
What else should I be checking into regularly? The reason I ask is because the fuel mileage fluctuates from 14-17 around town with an average of 15.
I have been told a 24V should be getting 18mpg. I don't hotrod it, but sometimes I do like to hear the turbo spool...
Thanks!
Old 04-10-2007, 12:36 PM
Olratlr's Avatar
Maintenance
That is all you probably get around town.
Open road 18-21 MPG
You should change your Transmission filter at least once a year and
adjust the Bands on your Tranny.
Old 04-10-2007, 12:47 PM
Rocky5.9's Avatar
So far it seems like you're on top of the maintenance. In town you're not gonna get great mileage but on the interstate you should see around 18. I get around 17.5 overall. Hopefully that'll go up when I get my valves adjusted.
Old 04-10-2007, 03:44 PM
RowJ's Avatar
Not fair to compare automatics with manuals. 15 MPG around town is average for heavy populated areas. I live in a rural area and get 16 around town... but only 10 lights in the whole town.
I average 16.7-17.5 mpg on 500 miles tests...depending on how often I have a load in the bed. That's probably 60% Hwy/40% town.
RJ
Old 04-11-2007, 11:27 AM
Thanks for the replies.
If I can't get a fleetguard air filter, which do you recommend?
Old 04-11-2007, 03:01 PM
fade94's Avatar
When I went with a BHAF, AH19037 Fleetguard number, it raised my MPG by about 2 mpg. They also last for several thousand miles, like a year or more.
Old 04-11-2007, 03:44 PM
RowJ's Avatar
What kind of mileage are you getting? Ever do a 500 or 1,000 mile mileage test??
RJ
Old 04-11-2007, 03:50 PM
fade94's Avatar
Originally Posted by RowJ
What kind of mileage are you getting? Ever do a 500 0r 1,000 mile mileage test??
RJ
When I drove 15 miles one way to work I was getting 18-19. When I go to Colorado I get 21-22 with cruise set on 80-82. If I take it easy and cruise at 60, I can easily get 23+. Pulling a 35' fully loaded truck and 5er from Colorado Spings over Wolfcreek Pass to Pagosa Springs, I got 12.
Old 04-12-2007, 11:44 AM
SIXSLUG's Avatar
Mine averages 15 around town.
RHC
03-25-2003 06:03 PM
Berak
03-22-2003 08:03 PM
Bill F
12-08-2002 09:18 AM
pappyman
11-24-2002 09:34 PM
dan239
10-23-2002 01:20 PM
Quick Reply: Maintenance
