Maintenance
Alright,
I have had this truck for 3 years now, and am wondering what else I can do to make it run for a good long time. Truck has 86,699 miles. I have changed the fluid in all of the following: Differentials, transfer case, transmission, power steering, brake system. I change the oil at the 7,500 mile interval and empty puke bottle; fuel filter ~15,000 unless I get a bad batch of fuel or mileage goes down. Stock airbox with stock filter, change as needed or 15,000 miles. What else should I be checking into regularly? The reason I ask is because the fuel mileage fluctuates from 14-17 around town with an average of 15. I have been told a 24V should be getting 18mpg. I don't hotrod it, but sometimes I do like to hear the turbo spool... Thanks! |
Maintenance
That is all you probably get around town.
Open road 18-21 MPG[coffee] You should change your Transmission filter at least once a year and adjust the Bands on your Tranny.[director] |
So far it seems like you're on top of the maintenance. In town you're not gonna get great mileage but on the interstate you should see around 18. I get around 17.5 overall. Hopefully that'll go up when I get my valves adjusted.
Not fair to compare automatics with manuals. 15 MPG around town is average for heavy populated areas. I live in a rural area and get 16 around town... but only 10 lights in the whole town.
I average 16.7-17.5 mpg on 500 miles tests...depending on how often I have a load in the bed. That's probably 60% Hwy/40% town. RJ |
Thanks for the replies.
If I can't get a fleetguard air filter, which do you recommend? Thanks |
When I went with a BHAF, AH19037 Fleetguard number, it raised my MPG by about 2 mpg. They also last for several thousand miles, like a year or more.
Originally Posted by fade94
(Post 1455003)
RJ |
Originally Posted by RowJ
(Post 1455066)
What kind of mileage are you getting? Ever do a 500 0r 1,000 mile mileage test??
RJ |
Mine averages 15 around town.
