Lost Manual High Idle
Old Dec 3, 2008 | 04:14 PM
JDonahue's Avatar
So it's just finally gotten cold here so I tried to use my high idle this morning when I started my truck hit the cruise on and set and no high idle. I had my truck into the dealer back in May for some warranty drivetrain work (LF axle u-joint, driveshaft u-joints and pinon seals) but nothing electronic. They did pull my dash apart to fix the rattling heater box they installed in January. Without flashing my computer it wouldn't have lost that capability right? And if they flashed my ecu there would be another tag under my hood stating what was flashed and when, right? Any ideas? Thanks, Jimmy
Old Dec 3, 2008 | 04:16 PM
06 DIESEL's Avatar
The dealer had to do something to the computer for it to stop. There is no other way to turn it on/off.
Old Dec 3, 2008 | 10:04 PM
6 Shaker's Avatar
My high-idle stopped working for me and I found that the wire to the clutch switch had fallen off.....something easy for you to check. Hopefully this helps.
Old Dec 4, 2008 | 01:51 AM
jkitterman's Avatar
Is your cruise control working?
Old Dec 4, 2008 | 05:50 AM
White97GTVert's Avatar
My truck was reflashed 2x without them ever putting the sticker on under the hood. Seems like it's automatic, they hook it up when they pull it in the shop and if there is newer software they flash it.
Old Dec 4, 2008 | 05:54 AM
05HDRAM's Avatar
I had the flash done for white smoke (didn't really do much), and my high idle was disabled. I took it back and they enabled it in a couple minutes. If they flashed, it could have reset that function.
Old Dec 4, 2008 | 08:42 PM
JDonahue's Avatar
Yeah the cruise works fine.
Old Dec 4, 2008 | 08:43 PM
JDonahue's Avatar
Great looks like a trip to my least favorite place....the dealer. Thanks for confirming what I was thinking!
kicker210
Dec 2, 2009 08:23 AM
jmccart
Jun 12, 2007 02:12 PM
the_fox_man4
Nov 25, 2006 02:05 PM
trophystock
Jul 23, 2006 06:00 PM
Patrick Campbell
17
Dec 2, 2003 08:03 AM
