Lift Pump?
Old 02-16-2010, 02:30 PM
shiveslandscapi's Avatar
Lift Pump?
Just bought my 03 3500 and i checked codes today and got the p0628 code. I am guessing lift pump is on way out. What should I replace it with?
Old 02-16-2010, 04:59 PM
woodzy's Avatar
Glacier makes a nice kit.
Old 02-16-2010, 05:28 PM
bansh-eman's Avatar
I am going to be replacing my LP with a Raptor once it is time. They do not require the fuel return line, and are rated for 16,000 hours of use. They are cheaper than the Airdog and allow you to run 1/2 fuel lines (supplied).
Old 02-17-2010, 07:57 AM
bullhauler05's Avatar
I did rapter and was well worth the money for sure
Old 02-17-2010, 08:36 AM
Ok so I should be good if I use the raptor 100 and run it to stock canister and drop a baldwin filter it canister. Will everything be supplied with the raptor to install it?
Old 02-17-2010, 08:44 AM
bansh-eman's Avatar
You will need to buy a Liberty canister for your in tank. They are about 100 bucks. Other then that everything you need is there.
I have heard of guys modding the stocker but I have not been able to find any info on what exactly needs to be done to it to make it work. The Liberty also helps get the draw straw deeper into the tank. Some people notice issues with picking up fuel when lower then 1/4 tank on steep grades. The Liberty can with the supplied draw straw with the Raptor from GDP fixes this.
http://www.glacierdieselpower.com/pr..._id=RP-100-D05
http://www.glacierdieselpower.com/pr...f_id=0511-FTSM
Old 02-17-2010, 09:15 AM
All my stuff was included with mine and it was a 150
Old 02-17-2010, 10:02 AM
I don't have an in tank one so I guess I will be good to go.
Old 02-17-2010, 10:15 AM
bansh-eman's Avatar
Call Richard at GDP and make sure there is no other little things you would need. I haven't dealt with an 03 so there might be something else that I don't know about.
509-993-4923
Old 02-17-2010, 10:23 AM
BlueOx1's Avatar
Raptor is way to go couple of hours to install,it seems like a good pump just looking at the thing it is probably 3 times the size of the orignal.
Txwelder
12-18-2023 02:35 PM
Txwelder
05-19-2005 06:10 PM
Yukon Dodge
18
07-01-2004 10:08 AM
Puke
05-22-2003 12:18 AM
Haulin_in_Dixie
47
11-17-2002 09:30 PM
Quick Reply: Lift Pump?
