Lift Pump Installed
Old Jul 18, 2005 | 07:54 PM
MKELLY's Avatar
Lift Pump Installed
Just finished the install on a new cummins lift pump. Total install took about 45 minutes THANKS to the great advice from the CREW @ DTR. Picked the pump up @ Cummins Metropower Inc. in Rocky Hill for 161.76. I also use a Holley Red Pusher Pump which gave the old pump a little easier life, but if was still given up the ghost. F.P. on new pump @ idle is 23, I haven't given her a run @ WOT yet maybe of the way to work tomorrow. Is 23 a little to high As always Thanks
Old Jul 18, 2005 | 08:04 PM
greenworks's Avatar
23 is fine, lots of guys including me idle pressure is higher. Bosch dealers I have talked to haven't ever seen a Vp blow seals and they have customers running 35+ psi. Si you will be fine.
However there will be someone who chimes in with the maximum 20 psi quote.
J
Txwelder
Nov 26, 2025 01:53 AM
big red psd cc
Jun 6, 2005 11:52 PM
Txwelder
May 19, 2005 06:10 PM
GSP
Oct 13, 2004 07:11 PM
spacely
Apr 4, 2004 09:35 PM
