What kind of fluid for NV4500?
Old 04-26-2007, 01:08 PM
Big Smoky's Avatar
I bought some Castrol Full Synthetic 75-90 GL5. Do yall think that would be alright to put in? The guy at Oreilles wasn't too knowlageable about anything. Also, how much fluid does it hold? I thought it was 3 or 4 quarts but I don't remember. Thanks a lot.
Old 04-26-2007, 01:27 PM
Box5's Avatar
It's gotta be rated GL4 not 5 for the syncro's. Only three choices I found are Castrol Syntorq, Amsoil has one similar, or Mopar nv4500 oil from the dealer. It's expensive stuff, $82 for 4 quarts of the mopar stuff. Mine took all 4 quarts and could probably use another 1/2 quart.
Old 04-26-2007, 01:51 PM
clutch1's Avatar
get the stuff from the dealer
Old 04-26-2007, 02:06 PM
crobtex's Avatar
The label on mine says "Castrol Syntorq".
Box5's Avatar
If you can find Castrol syntorq get that because it's cheaper than the mopar, and the owners manual said to use it or use the mopar stuff.
Old 04-26-2007, 02:21 PM
Hillcountry's Avatar
The syncros are sensitive in our trannys. If you use the wrong stuff it can destroy them. I stick to the stuff from the dealer because it is not worth the risk to me.
Old 04-26-2007, 02:23 PM
Box5's Avatar
like I said before, thankfully we don't need to do fluid changes in these trans... at 82 a pop! lol
Old 04-26-2007, 03:22 PM
BigBlue's Avatar
Get the right stuff eric. Your synchros aren't in good shape as it is. Remember the color of the fluid we pulled outta there? You get the shaft in yet?
Old 04-26-2007, 03:38 PM
Big Smoky's Avatar
The shaft came, but for some odd reason it got shipped to Elgin. Sowe had to meet my mom half way to pick it up. We just got back and we're fixin to start putting it back together.
Old 04-26-2007, 03:48 PM
BigBlue's Avatar
Good deal. I might skip out of CAD again but I doubt it.
Old 04-26-2007, 04:37 PM
mhuppertz's Avatar
I have run the Castrol Syntorq in my NV4500 for years of hard use without a single issue.
SilverSootXpres
03-23-2010 07:18 PM
ValkSmile
16
06-06-2009 03:13 PM
jshaw214
10-29-2007 06:48 PM
SMOKNISB
11-02-2006 06:01 PM
apache
10-11-2004 09:16 PM
Quick Reply: What kind of fluid for NV4500?
