View Poll Results: What type of truck with KDP damage
Automatic 2 wheel drive
12.50%
Automatic 4 wheel drive
25.00%
Manual 2 wheel drive
12.50%
Manual 4 wheel drive
50.00%
Voters: 8. You may not vote on this poll
KDP Damage
Old 01-21-2004, 11:20 AM
SmokinDodge12V's Avatar
KDP Damage
I was just wondering the type of truck that had problems with the KDP like auto 2wd, auto 4wd, 5spd 2wd or 5spd 4wd.
Old 01-21-2004, 01:36 PM
Rammin On's Avatar
You left out a choice .... All of the above ... I've seen damage in all flavors
Old 01-21-2004, 02:12 PM
pappyman's Avatar
I agree its not the configuration of the truck its the engine that has the KDP problem
Maybe a poll with model year would be more interesting and witch generation 1st or 2nd dodge and a mileage bracket that the failure happened at
I would be interested in guys that did the tap trick to know if the pin had moved and what year engine it was
I'm just rambling its your poll so you can set it up any way you want too
Old 01-21-2004, 02:18 PM
I alreay know what gens and what year was the worst for damage Im just trying to get an idea if there is any set up of the truck that may be more suseptical to damage.
Old 01-25-2004, 11:58 PM
OH  Sick's Avatar
I have a 95 and had Black Mountain Diesel do the drilling and inserting a cap machine bolt that stops the KDP from moving out of place. Cost 250,
Robert
Old 01-26-2004, 01:11 AM
Haulin_in_Dixie's Avatar
I currently have two '99 gear cases here, both are wide open and need to be modified to stop it from coming out. One was just mounted on the new engine, 24v.
Also a tip for 12 valve owners, if you have any trouble with leakage from the front cover, the 24 valve cover fits and is much stronger built.
Old 01-26-2004, 08:01 AM
Rammin On's Avatar
You got robbed ..... I do them for $50 .... less than an hours labor!
Old 01-26-2004, 02:25 PM
infidel's Avatar
$50 is a great price, but if a guy can change his own oil he can do the jig fix with common tools and a $39 jig.
Smokin96_12v
10-12-2009 07:39 AM
Burrito
05-10-2006 09:52 PM
Extreme Diesel
03-16-2006 10:08 AM
Ian
03-13-2005 10:31 PM
powerwagon440
09-23-2004 03:18 PM
Quick Reply: KDP Damage
