How to check for kdp damage?
Old Mar 14, 2006 | 10:30 PM
Extreme Diesel's Avatar
I'm looking at an early 98 and it has an oil leak at the front of the engine somewhere. It isn't severe, but enough to make the bottom of the ac compressor wet with oil. It doesn't leave any spots where it's parked. Any thoughts as to the best way to make sure I'm not buying a truck that needs a new timing case? Thank you guys very much!
Old Mar 14, 2006 | 10:33 PM
Dr. Evil's Avatar
Get a really bright light and closely inspect the front timing cover for cracks or holes.
Old Mar 14, 2006 | 10:48 PM
big jimmy's Avatar
And a mirror that can let you see behind the pulleys. It is very difficult to see the usual place the pin will crack the case- behind the fan drive pulley.
Old Mar 15, 2006 | 09:57 AM
infidel's Avatar
I've tried with a mirror, you can't see behind the pulley enough to be certain.
Short of pulling the pulley best bet is to clean the area up and identify where the leak is really coming from.
Most often a cracked case leaks much more than a gasket or seal, fresh oil will be evident even after a short drive.
Old Mar 15, 2006 | 03:24 PM
steven's Avatar
Do I have to keep the Dowel Pin? Can I just pull it and toss it?
I was planning on pulling the cover off to replace a leaking seal and to fix the dowel pin. I was told to just pull the dowel pin out and throw it away. Told its not needed. Is this correct? It seems like it wouldn't be needed once the case is in place. Why not just throw it away and not worry about it?
V/R
Steve
Old Mar 15, 2006 | 05:37 PM
TxDiesel007's Avatar
V/R
Steve
The KDP
must be tabbed, and pushed back into the hole that it came out. You cannot remove it. I have understood that it is supposed to keep engine parts aligned when the engine goes into the truck, may as well keep them aligned rather than mess with them and pull the pin out....
Use the TST kit.. 4 hours, and 50 bucks later, you can sleep better at nite
Rick
Old Mar 15, 2006 | 07:01 PM
DZLPWR's Avatar
When mine was leaking, i could stand in front of truck while running, rev. it up and hold a steady high rpm. and i could watch the oil start running out from underneath the idler pulley down the side of the timing case. Check my pics for location of crack.
Old Mar 15, 2006 | 07:06 PM
Geico266's Avatar
If it's not dripping when you park it's not KDP damage.
Old Mar 15, 2006 | 07:16 PM
Dr. Evil's Avatar
Nope....dont remove the pin (you probably cant anyway), throw the tab on, Loctite the other bolts under the cover and button it up.
Old Mar 15, 2006 | 10:38 PM
Thanks for the replies. I hope you're right. This looks like a nice truck and is exactly what I've been looking for. 98 12v auto qc sb sport with a gray cloth interior. It couldn't be more perfect accept for lower miles. It has 142k and it's $13,500 and all stock.
Old Mar 16, 2006 | 10:08 AM
For that price
it would be a steal here in Tx..... ive seen them with twice that mileage in that configuration go for 15K or so...
Good find! and best of luck with it...
Rick
Smokin96_12v
Oct 12, 2009 07:39 AM
Burrito
May 10, 2006 09:52 PM
Ian
Mar 13, 2005 10:31 PM
powerwagon440
Sep 23, 2004 03:18 PM
SmokinDodge12V
Jan 26, 2004 02:25 PM
