Jake Brake
Old 05-22-2005, 11:23 PM
12vordie's Avatar
Jake Brake
Has anyone ever tried to incorporate the same type of engine brake found on some of the big rigs into a cummins equiped dodge, instead of those crappy exhaust brakes, the sound is so much sweeter
Old 05-23-2005, 12:53 AM
RAFTEN's Avatar
Do a search, you will find out why we use those crappy e brakes.
Old 05-24-2005, 12:15 AM
Hemi Cat's Avatar
True Jake brakes bolt on top of the head and operate the valves on top of the rockers, and the valve covers go on top of the Jakes. One jake operates 2 cylinders. These engines do not have jakes designed for them.
Old 05-25-2005, 09:31 PM
bmoeller's Avatar
Depends on the nuber of heads on the engine. Some operate 3 cylinders at a time.
No one builds a compression brake for an engine smaller than 10L. Other than the swwet sound, the c-brakes have better braking horsepower, too. Even if they existed, you would probably have a ploblem of flat spotting the tires.
wvcowhauler
13
04-03-2005 11:39 PM
newtattoobob
43
06-12-2003 11:13 AM
KenR
01-10-2003 07:10 PM
Hunter
11-01-2002 12:11 PM
Quick Reply: Jake Brake
