idles rough at 1000rpm
i got an 04 ctd and started out with chugging sound and switched the truck back to stock with the proggrammer and now if you just sit still and idle the truck up to grand and higher it gets real rough and if your driving it will start cutting out real bad and almost die like knocking sound and smoking but then when you let out will go back to normal for a while then do it again wondering anyone ever had this happen thank you
If codes are not present when checked with a scanner, it sounds as though it could possibly be one or more injectors failing. Do you have any gauges to monitor boost, fuel pressure or egt??
F. Flack
18
08-10-2004 06:03 PM
