Idles fine stumbles above 1000rpm
Old Jun 5, 2013 | 11:20 PM
Tank_66's Avatar
I recently had the front end of my 98 apart replacing the gasket behind the timing case, all went well, but now I fire it up and it idles beautifully but if I rev it up to 1000rpm or higher it just spits and sputters and smokes like crazy, did I bugger up the timing???
Old Jun 6, 2013 | 01:16 AM
Tate's Avatar
Either cam timing or pump timing. Must be really retarded to stumble at 1k.
Old Jun 6, 2013 | 07:17 AM
Tank_66's Avatar
Ok sounds fair, I had the cam pinned plus marked where the gears were sitting to each other but I must have turned something
Old Jun 6, 2013 | 07:54 AM
patdaly's Avatar
Was the pump pinned as well?
Old Jun 6, 2013 | 08:00 AM
Tank_66's Avatar
Negative, I learned about the pump pun while searching why my timing was out, I guess my question is, I've got a 15 mile drive to town to get someone to do timing, what's the worst that will happen if I drive it there, and do I get them to advance my timing while I'm at it
Old Jun 18, 2013 | 07:21 PM
Tank_66's Avatar
Here's my latest update, the truck is supposed t go in for timing tomorrow, so I fired it up and was going to take it to town, let it warm up for a bit, drove to the end of the driveway and runs like a champ, I took it for an 8 mile drive ran great for the first 6 miles and the last two it started stumbling and smoking.... My question now is, I don't think it is timing as it ran just like it did before this issue, it smokes very heavy white and blue seems like a fuel problem, can anyone else chime in on this, I got the truck to a small stumble while idling and cracked all the injector lines but couldn't really hear any cylinder making it worse or better
Old Jun 18, 2013 | 08:10 PM
MikeR's Avatar
White indicates the timing is out. Just get it reset.
Pinning is never the right way to do it as things move when retorquing.
Old Jun 18, 2013 | 10:07 PM
Tank_66's Avatar
Ok, but in my mind the truck ran perfectly fine for 6 miles, then it started stuttering, the pump is mechanical why would it run good for that long then bugger up, shouldn't it of been out of whack from the get go
Old Jun 19, 2013 | 06:42 AM
lifer's Avatar
There is achance that you are getting air into the fuel system. That being said I would still get the truck timed. I would go to 15.5 on the timing instead of the stock 13 degrees. You will get better milage and more power. If it still does it after that I would check my fuel system for an air leak. The injector pump is held to the pump gear by a friction fit with a tapered shaft. They have been known to slip and this will change the timing. It is possible if the gear is not torqued correctly that it could move multiple times like andvancing from a hard deceleration and retarding from a hard acceleration .
Old Jun 19, 2013 | 12:27 PM
patdaly's Avatar
Depends, if you didn't get the shaft and bore PERFECTLY clean, they like to slip, sometimes in the first mile, sometimes a week later........ Have seen many over the years.
13ALPHA
24
May 4, 2012 01:15 PM
tweeter123
Jun 12, 2011 09:15 PM
Tazman
Jan 26, 2010 06:38 AM
kyle_truck_pull
Sep 20, 2009 01:02 AM
redpoint5
Jun 16, 2009 03:12 AM
