Idles rough when warm
Old Sep 11, 2005 | 06:29 AM
TerryS's Avatar
Truck runs great except for the hot idle missing touch the brake or put in gear or turn on the AC it goes away no codes everything checks out, think the VP44 is takin a poop?
Old Sep 11, 2005 | 07:20 AM
chaikwa's Avatar
My 98 does the same thing. I wish I could offer a solution, but it will be interesting to see if anyone else has this problem as well.
chaikwa.
Old Sep 11, 2005 | 09:03 AM
BIGROD's Avatar
If you have changed the fuel filter. You might try running some injector cleaner though it, like Power server. If I remember right, I had about the samething last year and that took care of it.
Old Sep 11, 2005 | 09:46 AM
Dr. Evil's Avatar
any codes thrown??
Old Sep 11, 2005 | 10:03 AM
TerryS's Avatar
No codes no smoke 17mpg. 80,000, miles intank FP OK press , new filter runs strong but will not idle right anymore.
Old Sep 11, 2005 | 10:11 AM
Dr. Evil's Avatar
Hmm, what exactly is the fuel pressure at idle, cruise and WOT??
Do you normally use fuel additive??
Sounds kinda like the VP....they dont always throw codes when they take a crap. Think I would run it for awhile ad see what happens.
Old Sep 11, 2005 | 10:39 AM
TerryS's Avatar
I have been running the PS for a few months hoping it would clear. I will try to rig a Carter or BD inline with the intank before I dump the cash on a new VP 44. Hoping someone beats me to it so I am not feeling like the intank FP guinea pig .To think I was happy when the ******* told me we upgraded you to the NEW intank pump. If I only knew.
Old Sep 11, 2005 | 10:50 AM
Dr. Evil's Avatar
Well, that was kind of an important detail to leave out. You say FP is good and Im asking specifically, what it is...idle, cruise, and WOT??
Old Sep 11, 2005 | 11:54 AM
TerryS's Avatar
12 idle 10 cruise 5 wot local rebuilder say he will warrantty the pump with those numbers but I dont want to be changing it twice.
Old Sep 12, 2005 | 10:26 AM
SmokeyBear's Avatar
i have same problem with my ride as do many others, tried everything except injectors and they got 135k on them maybe one is clogged. could be your problem also
Old Sep 13, 2005 | 08:07 AM
neveragain's Avatar
poor running
I wonder if you have what I have??? I have an arc in the PDC or wiring harness some where!!!!! I have seen it on a scope and I KNOW it is there. It is way toooooo technical cryslurrr and cummminnnnsss . Have them check it with the (break out box) to see if it runs smooth ? Mine will also cut out at between 1700 and 1800 and as high as 2200 under load!!!! I have been battling this since NEW. Nuf said if you think I have the right idea please PM me.
rage_blue
Oct 8, 2009 10:51 PM
bighornrmk
May 4, 2009 09:43 AM
grampaj
Jan 12, 2009 08:57 PM
F. Flack
18
Aug 10, 2004 06:03 PM
