hx-35 swap question
Old Aug 1, 2007 | 08:11 PM
ez_lle71's Avatar
hx-35 swap question
Ok
I did a search and read alot. Here is my questions,
1. My hx is a 2001 model, it has the cast elbow on the back. do i need the downpipe end that bolts up to it to modify my downpipe?
2. What kind of hose should i get to replace the line from the wastegate actuator to the compressor housing?
3. Where could a guy find a back plate to replace the elbow on the turbo to make it bolt up to my oem downpipe?
Thanks for the help!!
ez
Old Aug 1, 2007 | 09:29 PM
1stGen545's Avatar
You can use that or you can replace the bolted on pice on the back and put a 94-98 pice on it and it uses the same v-band clamp as the one you have. You will also need to remove the 2 studs from the turbo and drill it out to use the 4 in your manifold. You can use 1/4" air line to go from the compressor to the wastegate.
Old Aug 1, 2007 | 10:47 PM
ez_lle71's Avatar
Awesome!!! thank you for the answers. I have another quick question. My dad's 95' hx-35 has the plate i need with a cast elbow that is v clamped to it. Could i swap it with my 2001 elbow piece and it would all line up? It looks like it does the same as the one piece elbow on my 01'. If i can it would be great so i don't have to search for one. Thanks ez
Old Aug 1, 2007 | 10:59 PM
rockjeep73's Avatar
Yes, I believe they are the same dimensions and you should be able to directly swap them with each other.
Old Aug 2, 2007 | 05:48 AM
ez_lle71's Avatar
Thank you rockjeep73 and 1stgen545 for the valuable info. Will keep you posted!
ez
Old Aug 3, 2007 | 02:52 PM
ez_lle71's Avatar
Where can i get the gaskets for that wastegate cover flange thing iam replacing? The one i took apart is copper, would it be reusable? Thanks
ez
Old Aug 3, 2007 | 02:57 PM
Ilikebikes's Avatar
You could probably get the wastegate cover gasket from HTT. I've reused mine a few times with no leaks. If you're worried about leakage, but a thin layer of copper gasket maket on both mating surfaces, let set a few minutes then put it together. I used this trick when installing the hot pipe on my turbo setup and it doesn't leak at all.
Old Aug 3, 2007 | 04:42 PM
They never leak there unless you have an exhaust brake. It's fine to reuse them.
Old Aug 4, 2007 | 11:56 AM
ez_lle71's Avatar
Thank you wanna! that is the vote of confinence i needed! Im gonna use alittle of that copper gasket maker. figure it can't hurt.
ez
Old Aug 6, 2007 | 11:48 PM
ez_lle71's Avatar
Found out my dad's 1995 turbo is a WH1C!! Not a hx-35 like i thought! the parts i needed still fit so everything is cool!
bigwheels94
Jul 11, 2008 03:10 PM
Treangen
63
Jul 7, 2008 07:42 PM
Ian
May 8, 2005 03:13 AM
clc900
Jun 10, 2004 08:41 PM
joel
May 4, 2003 07:03 PM
