Hub Bearing Nut Size
Old 05-20-2011, 10:25 AM
cincydiesel's Avatar
In the process of replacing the hub bearing and need to know what size socket to remove the nut. I was told 1-11/16 but after buying one, its too small. Any help would be greatly appreciated.
Thanks,
Eric
Old 05-20-2011, 10:36 AM
jumper's Avatar
Shoot, I thought it was 1 11/16 too or I'd have looked last night. FWIW, my socket is a little temperamental and has to be rotated and squared up just right to line up. Odd, yes, but true.
Old 05-20-2011, 11:39 AM
Nascarcamper's Avatar
According to the Dynatrac instructions it is a 1 11/16" 6 point socket. You might just have a build up of rust on the nut, have you tried tapping not to be confused with beating the socket on? I looked in my Dodge manual and it states "use the correct size socket" allot of help that is!
Old 05-20-2011, 11:50 AM
I got it, it is 1-11/16. Some of the 'teeth' on the castle nut were bent causing the slots not to line up. After a little coaxing with some needle noses, I got it.
Thanks guys
Old 05-20-2011, 11:51 AM
Purplezr2's Avatar
Pretty sure that is the right size, it takes alittle tapping to get it on.
Old 06-10-2011, 08:19 PM
Thumbs down
Okay now it's my turn, attemping to install ball joints, passenger side axle nut came off with 4ft pipe on 3/4" drive breaker bar, driver side is twisting the 3/4" drive extension with 4ft pipe. Driver side is not left handed is it? I sprayed with PB Blaster and will try again in morning.
Old 06-11-2011, 06:18 AM
Hvytrkmech's Avatar
No it's right handed, an impact gun is your friend. Be prepared to have a very difficult time removing the wheel bearings.
Good luck
Old 06-11-2011, 06:46 AM
Thanks Tim, tried impact last night, will try again this morning after PB had a chance to work. Hopefully bearings won't be that bad, they were replaced about 3 years ago under warranty and I don't drive this truck in winter or salt.
Regards,
Tim
Old 06-11-2011, 01:16 PM
Thumbs up
Job complete, 4ft pipe comes through again along with some famous PB Blaster, great stuff.
Old 06-11-2011, 01:19 PM
Roadmedic's Avatar
Mine is 1 3/4.
Old 06-11-2011, 01:49 PM
IPDiesel's Avatar
I did my u joints last night-and after I broke the axle nuts loose with a 1-11/16" 12pt socket, I realized that you don't have to even remove it.
If you are changing ball joints, you can leave it assembled & just pull out the bearing, axle ect all in 1 piece.
Old 06-11-2011, 04:40 PM
Yes you can do it that way, XRF video shows it being done that way. My concern was re-installing the axle shaft, you need to slide shaft in just right and NOT damage the inner seal, IMHO it was just to much risk. My bearings came out with about a dozen slaps of the knuckle with the tie rod removed, slaps being hard on left turn stop and hard on right turn stop and they just popped out, guess the dealer anti-seized them. AMAZING!!
Old 06-11-2011, 04:51 PM
Hvytrkmech's Avatar
Thats a good deal Nascar, glad it went well for you overall.
Old 06-11-2011, 04:55 PM
Not bad at all, bearings and u-joints were still OK but I do need a caliper mount on driver side, seems the pads have worn through the stainless glides and had wore some pretty big groves in the mount bracket, will order new next week. Finally found my clunking noise at slow roll and rough road!!
bulldog_bones
09-13-2009 06:24 PM
Rafter B
01-11-2009 08:40 PM
04ctd
08-21-2008 07:02 AM
hknladdr
08-18-2008 07:26 PM
Crimedog
02-27-2007 10:39 PM
Quick Reply: Hub Bearing Nut Size
