Hub Bearing Nut Help
Old Sep 10, 2009 | 08:52 AM
bulldog_bones's Avatar
Is the Hub Bearing nut the Nut that holds the rear hub tight to the shaft keeping the inner and outer bearing tight on the shaft that the axle shaft goes through. If so, a manual that I was sent says it take 120 - 140 ft lbs. Thats about as tight as my lug nuts. Doesnt that seem a little tight for the bearings?
Old Sep 10, 2009 | 04:41 PM
Ramified5.9's Avatar
Is there 2 nuts? (A preload nut and then a lock nut?) I would say for the lock nut that tq setting sounds right. But not that much for the pre-load nut.
Old Sep 11, 2009 | 12:28 AM
4_play_ram's Avatar
Are you talking about the big 1 11/16 nut that sandwhiches the hub bearing and the outer axle shafts. If so than yes they are torqued to that, I just broke my 1/2 breaker bar trying to get that nut off. Thank you lifetime warranty. the nut I think bottoms out on the body that houses the bearing before it starts to squeeze the bearing.
Old Sep 13, 2009 | 10:15 AM
c-bass's Avatar
I just broke my breaker bar too...looks like it's time to start shopping for some 3/4" tools
Old Sep 13, 2009 | 06:24 PM
hector's Avatar
I broke my 1/2 bar on the front end last week.. I now have a 3/4 set
cincydiesel
13
Jun 11, 2011 04:55 PM
Rafter B
Jan 11, 2009 08:40 PM
04ctd
Aug 21, 2008 07:02 AM
hknladdr
Aug 18, 2008 07:26 PM
Crimedog
Feb 27, 2007 10:39 PM
