HOAT Coolant
Old 03-02-2010, 11:01 AM
dirtygoat's Avatar
HOAT Coolant
How important is it to run the HOAT equivelant coolant in the cummins engine? I had to make a last minute decision due to availability of coolant. I do intend on switching to a HOAT equivelant coolant in the near future. Is there anything to be worried about?
Old 03-02-2010, 11:29 AM
shonne's Avatar
I think the big thing is knowing what you mixed with it. I have always been very paranoid about mixing coolants. HOAT (Hybrid Organic Acid Technology) refers to a specific inhibitor package in the coolant itself. There are alternatives to HOAT. I am running Fleetguard ES Compleat™ OAT.
I see you are in Pflugerville. I am Hutto.
Hello neighbor.
Old 03-02-2010, 08:23 PM
kry226's Avatar
Agreed. The MOST important thing is ensure there is no mixing of different types of coolant.
Old 03-02-2010, 08:47 PM
bansh-eman's Avatar
Do some searching. Dr. Drizzle has covered this topic in depth of wh you need to use HOAT
Old 03-03-2010, 08:12 AM
rufushusky's Avatar
The guy I talked to at Cummins northeast said that Dodge required HOAT coolant due to the greater use of Aluminum in their vechiles, eg. the cylinder heads on the new hemi. I think so long as you completely flush the old coolant you can run a diesel rate low silicate coolant just fine.
Old 03-03-2010, 10:53 AM
Jeff in TD's Avatar
A buddy of mine who used to run a radiator shop once told me if he owned it, it would be hoat while under warranty, then flushed and run with tradational chemistry changed every two years...
Old 03-03-2010, 02:08 PM
dirtygoat's Avatar
Thanks for all the info...
traverler48
01-09-2011 07:38 PM
mstep3
05-04-2010 08:33 AM
mjsandt
65
12-15-2008 09:28 AM
papaduck
16
05-03-2007 08:17 AM
1stTimeAround
07-26-2006 11:50 AM
Quick Reply: HOAT Coolant
