HIGHBEAM RELAY (BRIGHT BOX)
Old 12-06-2003, 05:41 PM
ramcummins's Avatar
This is my first try at this site so I hope it goes.
I hear you guys talking about the "Bright Box" and you are paying upwards of $150 for it :'(, I found one from jc whitney (made for chevy but it works, part # 81ZX1821P) for $19.99 and put one in each of my trucks and they work great. the only drawback is you have to splice into your headlight wires, I added an inline fuse to the power wire and have been running it for over a year and it works great ;D 8)
Old 12-06-2003, 05:58 PM
ramcummins's Avatar
Re:HIGHBEAM RELAY (BRIGHT BOX)
And here I thought I had a revolutionary breakthrough :-[
Old 12-06-2003, 06:10 PM
DF5152's Avatar
welcome
Old 12-06-2003, 07:08 PM
Dr. Evil's Avatar
One more thing, running low and high beams may not technically be legal.....
Old 01-03-2004, 06:41 PM
VCFAB's Avatar
I tried to open the link for the headlight relay but it wasn't to be found. I am new at this but trying. Any help would be appreciated.
Old 01-03-2004, 07:01 PM
Robert Rausch's Avatar
I've installed used relays to operate lots of different electrical devices on lots of vehicles. My current favorites are old Caddy A.C. Relays. I bet I've collected dozens of them over the years and used them for horns, clearance lights, etc. etc.
The headlight fix is next on my Relay to-do list.
Old 01-03-2004, 09:18 PM
joefarmer's Avatar
The thread ID changed when they changed to new BBS softeware. The article is here:
https://www.dieseltruckresource.com/...threadid=25841
HTH,
brandon.
Old 01-03-2004, 09:43 PM
VCFAB's Avatar
Thumbs up
Thanks joefarmer this was a big help
Old 01-04-2004, 03:32 PM
10HAAP's Avatar
When making modifications to a design, it is wise to ensure the change won't exceed the capability of any part. In this case I am concerned about the headlight switch. My manual warns that there is no spare current available on 3500 trucks with cab lights and dually fender clearance lights, and that 2500 trucks without cab lights have only 4 amps available.
Another advantage to the relay approach is that the added light will get all of the vehicle's voltage, where the diode method will reduce the power by .6 volts.
getblown5.9
12-12-2007 06:15 PM
JWillms81
07-30-2007 05:00 PM
doug60
06-23-2004 09:36 AM
Cumminsdude
11-12-2003 12:23 AM
rattle_rattle
0
10-29-2002 04:05 PM
Quick Reply: HIGHBEAM RELAY (BRIGHT BOX)
