high idle acting up ?
Old Mar 5, 2008 | 08:08 AM
JMJ's Avatar
JMJ
I stared my pickup this morning, to let it warm up a little before work since it was about 10* out side and i couldn't get to a cord last night. The high idle kicked in and seemed to work, but about 5 sec after it dropped 3 clys it would drop back to low idle. Then as soon as it would get to low idle it would start idling back up to 1200 rpm switch to 3cyl. It did this about four times then finally it came up to 1200 dropped 3cyl and worked fine until i left for work. So is that a some what common ocurrance or is some thing wrong. Ive had this pickup for 4 months had the high idle turned on last month and this is the first ive heard it act up like this.
Old Mar 5, 2008 | 02:40 PM
klx650a2's Avatar
I had the same problem, but it was -26C with a 15 mph wind blowing into the front of the truck for 14 hours and the gfi plug tripped, so no oil pan or block heater. It would almost die once hitting the 3 cylinder mode numerous times, it threw a check engine light and was generally REALLY an unhappy motor (smoked out the block which was cool!!!). I ended up just using my manual high idle switch and all was well. After a few days the CEL went out...
Old Mar 5, 2008 | 03:56 PM
smokinram99's Avatar
what about the manual high idle switch? I want the High idle option for my 99... what type of parts? ECM program?
Old Mar 5, 2008 | 05:39 PM
babyjoe's Avatar
I would also like the hight idle for my 01, what do I need to do to get it.
Old Mar 5, 2008 | 11:33 PM
91rangerturbo's Avatar
You can have someone load a smarty on your truck and take it back off. Or take your truck to the dealer and have them update the ECM. Do a search and you will find a few big threads on it.
Old Mar 6, 2008 | 06:06 AM
Thanks! I'll check at the dealer...is this expensive?? Can I control idle with a switch? is there any kit for this?
I like set the rpm as I desire, I have listen that the high idle from the dealer(ecm upload) function when outside temp is low and other cold conditions..
Old Mar 6, 2008 | 10:15 PM
BigIron70's Avatar
Cummins Guru
Usually 1 hour The tsb 18-019-01
90 power ram
Mar 15, 2011 09:37 AM
kicker210
Dec 2, 2009 08:23 AM
cwrhnr
May 19, 2009 05:18 PM
jmccart
Jun 12, 2007 02:12 PM
dieselnewbie
Jan 18, 2005 10:48 PM
