High EGTs with new turbo
Old 06-06-2005, 10:15 PM
Kroner's Avatar
The truck has a 215 pump and no plate , everything else is stock except for exhaust / intake. With my stock turbo the temps climbed to around 1200* and it wasnt too bad i could still pull with it and keep it reasonable. Now I got a HTT stage 3 HX-35, and normal driving the temps are lower but if i get on it at all my temps climb to 1400-1500* very quickly. Do I have enough fuel to push it? What is the problem with it?
Kroner
Ps it has a 14cm w/g housing
Old 06-06-2005, 10:32 PM
Ram2Pete's Avatar
what kind of boost are you seeing and with it spooled how much smoke is there
Old 06-07-2005, 07:58 AM
Kroner's Avatar
Boost is around 30-35lbs. Smoke depends I can really roll smoke at low rpms but at WOT its a light haze to clear.
Old 06-07-2005, 08:19 AM
RowJ's Avatar
What kind of boost with stock turbo? Was there more smoke before? If you are now getting more boost...maybe your also getting more HP (burning more fuel)....and therefore more EGT's.
If you changed nothing else but the turbo....I would still expect lower EGT's. Have you discussed with Paul at HTT?
RJ
Old 06-07-2005, 11:28 AM
vssman's Avatar
Boost seems a little low. My stage 3 is regulated to 44-45 psi but I'm running a 12 housing. If you have an adjustable elbow, screw it in a bit and bump up the boost to the upper 30's to start.
Old 06-07-2005, 07:10 PM
Kroner's Avatar
Boost with the stock turbo was 40lbs. I checked again after work and 30lbs is where it is set at. Smoke is less at higher rpms but mostly the same in the lower range. Where is the elbow to adjust boost?
Thanks for the help
Old 06-07-2005, 08:00 PM
jrs_dodge_diesel's Avatar
I believe you are getting less air with your new turbo compared to the original. (30 psi boost compared to 40psi) I would try to adjust the elbow.
Old 06-07-2005, 08:20 PM
Kroner's Avatar
Do I turn the elbow on the front of the turbo? Does just screwin it in change the pressure?
Old 06-07-2005, 09:17 PM
bmoeller's Avatar
If the boost elbow is adjustable, it has a small set screw in it. Need to turn the screw in a little, to raise the boost.
Old 06-07-2005, 09:55 PM
Kroner's Avatar
There is no set screw...so what do I do to raise boost? We are talkin about the elbow below the intake right?
Old 06-07-2005, 11:08 PM
No, no. Not along the main air pipes. Look for a small line going to the wastegate. You should see an elbow along the way.
edit : don't confuse it with the oil feed line.
Old 06-08-2005, 08:19 AM
Kroner's Avatar
There is an elbow below the intake on the compressor side and it is connected to a little blue hose that goes to the wastegate but there is no set screw in it. How do I raise the pressure if there is no set screw? The guy who pulled my plate out adjusted the screw on the back of the afc housing which raised my pressure the first time. Wish I would have paid more attention.
Old 06-08-2005, 09:36 AM
RowJ's Avatar
Lower boost would acct for higher EGT's. Just disable the wastegate completely for now.
Should not be more than the 40 psi you had before and thats not too much for new turbo!
RJ
Old 06-08-2005, 11:02 AM
gunracer1's Avatar
i would suggest that you put a plate in that pump, unless you have your timing around 30 degrees or more.
Old 06-08-2005, 11:59 AM
vssman's Avatar
The brass elbow is on the front of the compressor housing and has a tube that goes from there back to the wastegate. You need an adjustable elbow which is your regualr elbow with a setscrew in it. You screw the set screw in to raise the boost as it effectively restricts the air pressure to the wastegate. Look in the classifieds here & on the TDR. Should be maybe $20.00
As for the plate - there has been a longstanding debate about running plateless. Most believe you can damage the pump if a pin breaks without the plate in it. If you do decide to put one in, I'd go with a #10.
jwb600
31
10-25-2008 10:37 AM
lgp9999
09-08-2007 11:19 PM
BCarmicle
09-22-2004 12:10 PM
Towrig
18
07-16-2004 02:34 PM
NOTSTK
08-09-2003 09:10 AM
Quick Reply: High EGTs with new turbo
