Headlight, Key, Door Chime
Old 08-03-2005, 07:18 AM
Luckycharm1's Avatar
My dad just bought a 94 ram. The door/headlight/key chimes were yanked out before he bought it. Does anyone know the wiring diagram for the plugs to the left of the fuses to add an aftermarket buzzer to get the headlight warning to work again?
Old 08-03-2005, 08:31 AM
Mopar1973man's Avatar
It a single module the plugs in under the knee bolster... I pull mine out so I can listen to the CD player when I'm working in the yard without the buzzer.
Go to a wrecking yard and pull one out... the plug it in...
Old 08-04-2005, 12:24 PM
TN Redneck's Avatar
Thanks for the tip. I am going to look for that dang thing this evening so I can leave the door open and enjoy the stereo.
Does it have any identification or ist it obvious when you pop the knee bolster off?
Old 08-05-2005, 08:19 PM
I already have a generic buzzer I would like to use, just don't know what connectores to use. Anyone have any ideas?
Old 08-06-2005, 08:10 AM
Right side of the opening on the knee bolster. It a little brace with a black box plugged into it on the 1996 dodge... On the newer trucks (2002) it a larger box that has the chime in the same place but I don't think you can unplug the newer ones.
You could wire into the stock connector... You should be able to test the socket for power when the door is open.
Old 08-08-2005, 09:06 PM
putzer's Avatar
you can have mine......... the buzzer thing that is, pretty sure it is the same
Old 09-01-2005, 07:12 AM
Putzer, It arrived safe and works great! Thank you so much for all your help. It will sure save me jumping dad's truck off when he leaves the lights on! Ha! Thank you!!
Old 09-01-2005, 07:25 AM
firestorm's Avatar
I unplugged the wire from the key switch on mine. It still dings if the lights are on and the door is open, but does nothing if the key is in the ignition with the door open. The down side to this is, the ring around the ignition switch does not light up, no biggie. If you drop the plastic cover from the underside of the steering wheel column, by the key switch, there is a plug with 2 or 3 wires right there. Just unplug it.
dodgetrucker75
12-19-2012 04:41 PM
hovisimo
17
04-21-2005 09:22 PM
procrastinator
19
02-15-2005 11:06 PM
jrs_dodge_diesel
23
11-25-2004 12:00 PM
hilclmr
06-10-2004 10:52 AM
Quick Reply: Headlight, Key, Door Chime
