Haunted cargo light???
Old Feb 4, 2008 | 07:43 PM
Billut's Avatar
The cargo light comes on whenever it feels like and stays on. Sometimes it takes several "held-pushes" on the switch to turn it off, it goes off... and several hours later, randomly, comes on again... Spooky, uh?
Has anyone had the same curse?
Old Feb 4, 2008 | 08:43 PM
NoSparkplugs's Avatar
I did and I believe its the switch, ended up taking it out (ok accidentally breaking it trying to disassemble it) and then I found out that Dodge no longer makes that part...great. I suppose you could wire in a generic toggle switch?
Old Feb 4, 2008 | 09:01 PM
Billut's Avatar
Thanks, NoSparkPlugs. I suspect the switch, too. the sucker is tucked way where it's almost impossible to get to without dropping the dash, oh well...
Old Feb 4, 2008 | 10:24 PM
The switch is easy to pop out, just press the 2 tabs on the side of the switch (behind the dash part) and disconnect the connection and its out.
Old Feb 4, 2008 | 10:36 PM
torquefan's Avatar
I can't picture where the cargo light switch is on 1st gen trucks. Where is it and what does it look like?
Old Feb 4, 2008 | 11:03 PM
Free89W350's Avatar
Its directly on the other side of the column from the head light switch and it looks like a OD button, small square and lites when you push it even if the cargo light doesn't.
Old Feb 5, 2008 | 03:56 PM
Billut's Avatar
Hey thanks again NoSparkPlugs! I was really annoyed with the idea of pulling the dash out.
Old Feb 5, 2008 | 10:36 PM
torquefan's Avatar
Gotcha. Thanks.
stratos201proxl
Jan 16, 2014 11:04 AM
Justwannabeme
Feb 12, 2008 01:08 PM
Diesel_Storm
Sep 14, 2007 06:00 AM
ROOSTER108BM
Feb 14, 2007 06:44 PM
gerry
Nov 9, 2005 11:03 PM
