hard start
Old 07-12-2007, 04:49 PM
carleshicks's Avatar
hard start
About 4 weeks ago my truck started taking a few seconds to start, after 3 days of this it would not start, i thought maybey I got some bad fuel so i changed the fuel filter and it started right up. the old filter was completly black. after about a week it did it again so i changed the fuel filter agian and it starts right up the filter was dirty but not that bad, well today it is starting hard again. Do i have some dirty fuel in my tank or is my transfer pump going bad.
By the way I drive over 75 miles aday and my truck is an 03 HO 6 speed
Old 07-15-2007, 06:31 AM
I had to change my fuel filter yesterday, any body have any advice
Old 07-15-2007, 06:48 AM
MikeyB's Avatar
Could be the transfer pump going out. Also hard starts can be caused by leaking injector(s).
How many miles on the truck?
MikeyB
Old 07-15-2007, 11:47 AM
133,000 miles. how would i test for leaky injectors
Old 07-15-2007, 12:10 PM
pgcountycop's Avatar
I've noticed that even in warm temperatures, I need to turn the key to on for a few seconds before starting. This allows the lift pump to run and get fuel before starting. It's almost as if the fuel drains away when idle for a few days. Not a big problem. This might work for you as well.
Old 07-15-2007, 01:50 PM
MikeyB's Avatar
The dealership. Will use the DRB scan tool for testing the injectors.
MikeyB
Old 07-19-2007, 10:32 AM
I think the transfer pump is the culprit, should I replace it with the in the tank factory replacement or an after market. I have a freind at the Dealership that will install the factory in the tank pump for $300 out the door.
Old 07-19-2007, 10:45 AM
dodgezilla04's Avatar
aftermarket.
comparable price. one mounted on the framerail can be replaced in 20 minutes on the side of the road if the need arises.
an intank pump that has failed is miserable to fix. it always happens with a full tank of fuel, raining cats and dogs, nowhere near your garage.
Old 07-24-2007, 06:43 PM
I just replace the transfer pump with the kit from Glacier Diesel pruducts and it is still doing the same thing. what do I check next the injectors?
Old 07-25-2007, 07:59 PM
Has anyone had experience with leakiy injectors or rials causing no starts and hard starts.
Old 07-25-2007, 08:13 PM
OldSmokey's Avatar
You may get some fuel in the engine oil. Check your oil level and to see if it smells like diesel.
jacob_armour
02-18-2009 01:44 PM
jckdann7
08-31-2008 12:13 PM
jriggs_18
01-11-2007 04:43 PM
Erik Dlux
24
12-08-2004 07:26 AM
Quick Reply: hard start
