how hard to replace stock lp on the side of the road?
Old 05-11-2008, 11:46 AM
20tony20's Avatar
I have over 150,000 on the original lp in my early 04 and thinking of getting a replacement from Genos for when the inevitable happens. How hard would it be to replace on the side of the road? What tools do you need, and are there any instructions online anywhere? thanks for the help.
Old 05-11-2008, 02:06 PM
87BRGN's Avatar
If it's just a replacement filter mounted pump, you can do it in 10 minutes hood open to hood close.
Unplug wire harness
Remove 4 allen(?) bolts holding pump on back of filter housing
Remove feed line from bottom of old pump
Put fuel feed line on new pump with clamp
Press nipple into housing
Replace 4 bolts
Plug in wire harness
Turn on key to prime filter ( you might have to bump starter )
Get Back on the road.
Tools needed: other than allen wrench( cant remember the size) a pair of pliers for the squeeze clamp on the bottom of pump.
I've did it twice on mine before I got rid of the crappy design. Keeping a spare filter and pump relay might be a good idea also. The second time mine went it burned the relay also. I just pulled a swap to get me to Napa.
Dave
Old 05-12-2008, 02:48 PM
Raspy's Avatar
You're definately on borrowed time. Why not put a good aftermarket one in at home instead of a crappy stock replacement one in on the highway?
John
Old 05-12-2008, 05:21 PM
XLR8R's Avatar
What year is the OP's truck?
Old 05-13-2008, 02:32 PM
jballou's Avatar
5mm allen bolts. Not hard to do.
Old 05-14-2008, 01:25 PM
Peterbilt's Avatar
Replacement pumps are hard to find. I'd like to have a spare.
Pete
Old 05-14-2008, 08:46 PM
20tony20's Avatar
Geno's garage has them for 179.00.
Old 05-15-2008, 01:55 PM
lamadera's Avatar
Yeah, good way to go if you're still under warranty. Replace it while the old one still works before you have to do it on the side of the road. When I'm out of warranty I'll get a real pump.
bandit1trucking
02-14-2019 08:16 AM
vanwinkl
01-31-2007 06:20 PM
I PASS GAS
10-02-2006 05:02 AM
243
01-27-2005 11:44 AM
Mule Skinner
11-16-2002 06:57 PM
Quick Reply: how hard to replace stock lp on the side of the road?
