how hard to replace stock lp on the side of the road?
I have over 150,000 on the original lp in my early 04 and thinking of getting a replacement from Genos for when the inevitable happens. How hard would it be to replace on the side of the road? What tools do you need, and are there any instructions online anywhere? thanks for the help.
If it's just a replacement filter mounted pump, you can do it in 10 minutes hood open to hood close.
Unplug wire harness Remove 4 allen(?) bolts holding pump on back of filter housing Remove feed line from bottom of old pump Put fuel feed line on new pump with clamp Press nipple into housing Replace 4 bolts Plug in wire harness Turn on key to prime filter ( you might have to bump starter ) Get Back on the road. Tools needed: other than allen wrench( cant remember the size) a pair of pliers for the squeeze clamp on the bottom of pump. I've did it twice on mine before I got rid of the crappy design. Keeping a spare filter and pump relay might be a good idea also. The second time mine went it burned the relay also. I just pulled a swap to get me to Napa. Dave |
You're definately on borrowed time. Why not put a good aftermarket one in at home instead of a crappy stock replacement one in on the highway?
John |
What year is the OP's truck?
5mm allen bolts. Not hard to do.
Replacement pumps are hard to find. I'd like to have a spare.
Pete |
Geno's garage has them for 179.00.
Yeah, good way to go if you're still under warranty. Replace it while the old one still works before you have to do it on the side of the road. When I'm out of warranty I'll get a real pump.
