hard pull to right side
Old 07-05-2007, 11:41 PM
Muted User
LOGAN's Avatar
just started pretty bad in the last couple days, you let go and in about 50 feet your in the ditch. i got a "pop" in my steering when i am setting still running and turn the wheel left and right lock to lock, i can feel it through the floor board, all the suspension and tires and everything looks ok, i am putting my new wheels on tomorrow so i will take a closer look. think it needs a steering shaft?? what does the borgeson shaft run?? is it worth it?? i might just make my own or something, i will find out tomorrow though.
Old 07-05-2007, 11:53 PM
90firstgen's Avatar
I've had this same problem for awhile now. I hope somebody knows the answer!
Old 07-06-2007, 12:04 AM
simplysmn's Avatar
I would make sure your box is still tight up against frame and check for cracks around box also .If everything looks ok then I would look at allinement or maybe even a bent wheel or loose tierod ?
Old 07-06-2007, 12:55 AM
Muted User
LOGAN's Avatar
i cant see the steering box all of a sudden coming loose along with the frame cracking but that could cause the "pop" sound, or the bent wheel, i havent hit anything, and it started all of a sudden, like someone flipped a switch, tie rods look ok but im going to dig into it good tomorrow. truck has never been abused, it never pulled anything til my dad got it, and that was a bobcat like 3 or 4 times.
Old 07-06-2007, 08:24 AM
simplysmn's Avatar
Also lower control arm bushing's jack it up and then turn wheels and see where slop is comming from .and yes I have seen box tight one day and loose as a goose the nextthings happen .
Old 07-06-2007, 09:14 AM
Jschlachta's Avatar
If all the steering components are tight it could be kingpins are worn, kingpin bushings or kingpin springs. I replaced my kingpin bushing a while back and one of them had spun 30 degrees or so. I need to tear it all down and look at the lower bearings on the knuckle also. To check the upper part just remove the 4 bolts on the top of the knuckle with weight off the wheel. not that difficult to do but lots of grease in there.
Old 07-06-2007, 01:36 PM
mhuppertz's Avatar
It's probably a combination of things, but I would rotate the tires and see if there is any change.
Old 07-06-2007, 05:24 PM
Sounds like a control arm bushing to me.
Old 07-06-2007, 10:42 PM
Muted User
LOGAN's Avatar
loose idler arm was the popping and the pulling, im going to have school align the truck next week probably. i had my buddy start the truck and turn the wheel and it was moving all over the place, i took both nuts off by hand.
Old 07-07-2007, 01:06 AM
ram93's Avatar
i have the same problem with my 93 and its the bottom bolt that connects the steering box to a plate that connects to the frame. have somebody crank the wheel and watch the steering box.
edd209
09-06-2010 03:31 AM
Alan_Reagan
07-26-2009 01:13 PM
cquestad
258
01-22-2006 09:58 AM
fearthedeere
05-16-2005 07:53 AM
fitzydog
03-04-2005 03:37 PM
Quick Reply: hard pull to right side
