gear oil
Old Apr 26, 2008 | 10:05 PM
dodgethis91cmns's Avatar
gear oil
how many quarts of gear oil does the dana 70 take. and when i crack my rear what can i look for as signs of wear and tear, and what do i check to make sure its all good?
Old Apr 26, 2008 | 11:17 PM
put a big magnet on the rear cover before you take it off and drive it a little bit...then take cover off and see if theres metall.....theres sometin to do
Old Apr 27, 2008 | 02:05 AM
Confedpirate's Avatar
make sure that your ring gear doesnt have any sharp edges or grooves then its time for mew ring and pinion
Old Apr 27, 2008 | 08:53 AM
3.5 qts. "Full" is 1/2" to 3/8" BELOW the fill hole. Extra usually winds up in the brakes.
Old Apr 27, 2008 | 01:32 PM
Tron's Avatar
Check for any side to side play in the carrier. Uses a small pry bar to move it back and forth. Driver side carrier bearings like to wear out with added hp. There should no play at all.
Elk_Hunter
Jun 13, 2010 09:41 PM
JohnInNH
15
Sep 3, 2006 08:22 AM
mhuppertz
Aug 19, 2006 09:17 AM
trout74
Aug 29, 2005 06:25 PM
Hummin Cummins
Dec 25, 2002 12:29 AM
