Fuel Pump Leak!!
Hey guys ,
My fuel pump on my 92 diesel is leaking
and I was wondering if there is a way to fix it without buying a new one. I have already checked with dodge and it is 200.00 for a new one. Any ideas?
and I was wondering if there is a way to fix it without buying a new one. I have already checked with dodge and it is 200.00 for a new one. Any ideas?Thanks
Only one thing to add: if you're looking for quite a bit more power in the future you may want to look into a piston lift pump. They are quite a bit more expensive, but they won't starve the VE in the upper HP levels. However, if you plan on staying stock or close to it, the piston pump isn't worth it.
I just installed my piston LP this last weekend and all I can say is WOW!! I practically tripled my FP at idle, went fro 6psi to about 15psi. Don't know what it is at WOT but i'm sure its more than 0psi. Before it would pull to about 3000rpms and pretty much that was it, now it'll pull to 3250 and probably keep pulling but I get scared and back out.
Just wish I would have put it on sooner as my IP is dying.
ZPOD
18
Sep 23, 2010 10:37 AM
donhov
26
Jan 6, 2006 07:29 PM
Bobcat698
Nov 21, 2005 09:19 PM
amartinson
0
May 4, 2003 01:55 PM
usdieselparts.com has them for around $40 shipped.
