fuel pressure gauge install on 04.5'
Old 01-26-2005, 03:24 PM
deezulsmoke's Avatar
Can someone jump in and elaborate on the install procedure for a fuel pressure gauge on the 04.5 ?? I am probably going to just install the gauges myself and I wasn't sure if I needed any extra fittings to install the gauge or not ?? I noticed genos sells a fuel filter cap with a fitting in the top that fits the fuel pressure gauge. My question is do you want to monitor fuel pressure before or after the fuel filter ???
Old 01-26-2005, 05:10 PM
john@dps's Avatar
Location: 7750 Sepulveda Blvd Unit #1 Van Nuys, Ca 91405
After is fine. We also sell the install kit that makes the install a breeze, just so you know.
John
Old 01-27-2005, 07:53 AM
J.DAVY's Avatar
I installed one on my 05 yesterday got the whole kit from Piers ,fairly easy took about 2 hours with putting on my pillar.But I had help from my 3 year old.I put mine right at the inlet to the cp3 pump.
Old 01-30-2005, 02:27 PM
J.DAVY's Avatar
Sorry,never took any pics but the banjo bolt comes in the kit.There was nothing for third gen instructions but I just followed the line from the filter housing to the cp3 and switched the stock bolt for the one the came in the kit,it comes with new copper washers as well.
Old 01-31-2005, 10:40 AM
Maccandy's Avatar
I got a banjo bollt and washers from Genos and tapped into the bottom of the filter holder. That way I am monitoring post filter. Remove the wheel liner and you will have easy access to the filter holder. Easy job.
dodgeguy71
17
01-19-2012 12:52 AM
ado2b1
07-06-2007 10:27 PM
rleeke
01-04-2005 03:28 PM
PapaSmurf
09-02-2004 08:25 PM
BADBOWTIE
11-19-2003 06:27 PM
Quick Reply: fuel pressure gauge install on 04.5'
