fuel pressure gauge install on 04.5'
Old Jan 26, 2005 | 03:24 PM
deezulsmoke's Avatar
Can someone jump in and elaborate on the install procedure for a fuel pressure gauge on the 04.5 ?? I am probably going to just install the gauges myself and I wasn't sure if I needed any extra fittings to install the gauge or not ?? I noticed genos sells a fuel filter cap with a fitting in the top that fits the fuel pressure gauge. My question is do you want to monitor fuel pressure before or after the fuel filter ???
Old Jan 26, 2005 | 05:10 PM
john@dps's Avatar
From: 7750 Sepulveda Blvd Unit #1 Van Nuys, Ca 91405
After is fine. We also sell the install kit that makes the install a breeze, just so you know.
John
Old Jan 27, 2005 | 07:53 AM
J.DAVY's Avatar
I installed one on my 05 yesterday got the whole kit from Piers ,fairly easy took about 2 hours with putting on my pillar.But I had help from my 3 year old.I put mine right at the inlet to the cp3 pump.
Old Jan 30, 2005 | 02:27 PM
J.DAVY's Avatar
Sorry,never took any pics but the banjo bolt comes in the kit.There was nothing for third gen instructions but I just followed the line from the filter housing to the cp3 and switched the stock bolt for the one the came in the kit,it comes with new copper washers as well.
Old Jan 31, 2005 | 10:40 AM
Maccandy's Avatar
I got a banjo bollt and washers from Genos and tapped into the bottom of the filter holder. That way I am monitoring post filter. Remove the wheel liner and you will have easy access to the filter holder. Easy job.
dodgeguy71
17
Jan 19, 2012 12:52 AM
ado2b1
Jul 6, 2007 10:27 PM
rleeke
Jan 4, 2005 03:28 PM
PapaSmurf
Sep 2, 2004 08:25 PM
BADBOWTIE
Nov 19, 2003 06:27 PM
