fuel pressure gauge install??
Old Aug 31, 2004 | 09:44 PM
PapaSmurf's Avatar
Hello
A fella I work with bought gauges for his truck a 03 HO with the 6 speed. He tapped into the fuel line coming from the bottom of the fuel filter running to the high PSI pump is. ( I think that is what it is) It goes to where the injection pump is suppose to be.
He is seeing 7 psi at an idle and and sees the psi drop a few psi when rowing through the gears, but with his Bully Dog Torque Dog box sent at the high output setting it drops to 0 . I told him that is'nt a good thing and if it was my truck I would try and keep at least 2 or 3 psi. I am thinking old school where the fuel COOLed, CLEANed, LUBEd and of course made the engine run.
I have my own interest in this for my wife's truck which I recently added a edge EZ box. I have not installed a fuel psi gauge to her truck yet, I will be ordering one this week.
Question
1 What is the safe fuel psi for this engine?
2 What are you doing to supply more fuel pressure?
3 Where did you tap into the fuel system to get your readings?
Thanks for your help. The new trucks are a bit different than the old stuff.
Trying to learn as much as I can about the 3rd Gens.
See Ya
Chris
Old Sep 1, 2004 | 10:12 AM
cmnspwr's Avatar
Hey Chris, Johnner has been through this and found the limits of the system. He has a Holley Blue with -6an stainless and aeroquip fittings on his 04. Send him a PM (Banshee) to see where he tapped for the gauge.
Old Sep 1, 2004 | 11:59 AM
doug's Avatar
I'm experimenting now with using the boost channel of the SPA technique gague to read fuel pressure. I put six feet of 1/4" fuel hose on the sender, and connected to the CP3 low side point using a tapped banjo. bingo, have a $15 fuel pressure gauge. We'll see if the electronic sender itself can tolerate the abuse...
I see 8 lbs at idle, and all of the aggressive pressure boxes (Quadzilla, Bullydog, Banks, Volumizer, Predator 3) pull it down to 0 or 1 psi. thats what you get for raising rail pressure to 26,000-27,000 psi. the low side can't keep up with the flow requirements.
Moderate fueling boxes like the EZ and VA maintain a higher pressure on full load. But the EZ, at 70HP, still gets close to zero.
Old Sep 1, 2004 | 12:30 PM
cquestad's Avatar
Doug, did you test the VA CP3.2?
Old Sep 1, 2004 | 12:38 PM
doug's Avatar
not yet! soon to come though. In general I expect a pretty good correlation between low-side fuel pressure drop and the gain in horsepower output. Its just fuel in fuel out, whether you accomplish the additional fueling via pressure or duration. I just haven't measured peak horsepower yet on these boxes so I don't know how creatively they have been reported. I'm just thinking here that a "100HP box" (depending on what that means) will drop pressure to near zero.
I'd like to see more of Banshee's work on this. From talking to Rod@Wildcat, I have particular interest in the Holly blue because of its lower peak pressure output (appears to be better regulated)
Old Sep 1, 2004 | 01:09 PM
cquestad's Avatar
I will do a pusher of some sorts soon as well!
Old Sep 1, 2004 | 06:51 PM
Car_nut57's Avatar
That is a good place to get the fuel pressure readings from, after the filter and before the pump. 7psi is pretty normal and it will drop with fuel demand.
Old Sep 2, 2004 | 08:25 PM
PapaSmurf's Avatar
Thanks, CMNSPWR
I will talk to Johner and see what he done with his truck.
Thanks for the information.
See Ya
Chris
dodgeguy71
17
Jan 19, 2012 12:52 AM
ado2b1
Jul 6, 2007 10:27 PM
dzpoorjr
Jan 9, 2005 11:01 PM
rleeke
Jan 4, 2005 03:28 PM
BADBOWTIE
Nov 19, 2003 06:27 PM
