Fuel Pressure Concern
Old Sep 28, 2007 | 10:42 PM
Silver 002's Avatar
Hey does anyone know what a stock 600 hundred motor should be running for fuel pressure. I have a quadzilla fuel and rail digital gauge and all i have seen is 7 for fuel at idle, and as soon as step into it all is gone running with everything turned off, on, and even with my quad plugged in. i need some help i got beat by my friends duramax running with a edge hot juice.
Old Sep 28, 2007 | 10:44 PM
rufushusky's Avatar
hmmm...sounds like you need a new lift pump...7psi is pretty low for idle with only a quad box...
Old Sep 28, 2007 | 11:05 PM
trx's Avatar
trx
i see 9psi at idle and down to 5 psi under wot smarty on #7
Old Sep 28, 2007 | 11:10 PM
rufushusky's Avatar
hmmm...maybe I am wrong...I heard that it is bad for the pump to be under 5psi...is that true?
Old Sep 28, 2007 | 11:15 PM
Silver 002's Avatar
ya i dunno i heard it wasnt as big of deal on these new common rail engines
Old Sep 29, 2007 | 12:20 AM
TNLoneWolf's Avatar
My '05 Zilla RPG starts at 0 with the key on and idles between 4 & 5, but it's always moving around. My "rail pressure" flutuates in the 6300-6800 psi range at idle. Where is your "rail" pressure at idle? I've checked the high end after driving and only ever seen a high of 8 psi once. The highest "rail" pressure I've seen is 26,820 or something like that. Not sure if this helped you any. Check my SIG...
Old Sep 29, 2007 | 04:01 PM
Silver 002's Avatar
my rail holds there right there with yours right under seven grand and i havent got quite 26,820 but with my quad xzt i have seen right at 25000
Old Sep 29, 2007 | 08:09 PM
pos dodge's Avatar
im running fass and it stays around 16 to 17. i dont know if its good or not. That rail pressure gauge i got is trash i think. When i hook it up to the fuel rail sensor the truck runs like crap and when you turn the motor off the engine rpm raises then shuts off. And with the sensor connectors unhooked from the sensor, (just dangling) im still getting readings. I dont understand what is wrong with it, seems that something is shorted.
Old Sep 30, 2007 | 08:44 AM
Mark1si's Avatar
My stocl lift pump would push 6-8 psi at idle. Man you gotta love the Fuel Boss 14-16 at idle and what eer you want while cruising.
Old Sep 30, 2007 | 10:16 AM
Twisted2500's Avatar
Mine idles at 7 as well... Then it drops off pretty quick with some pedal. A little worried for the CP-3 but rail pressure stays up, I have seen a little over 27k. Mechanical fuel system next
Old Sep 30, 2007 | 12:43 PM
Fisherguy's Avatar
"hmmm...sounds like you need a new lift pump...7psi is pretty low for idle with only a quad box..."
No, that's actually quite normal, my stock pump puts out 8psi at idle, I can draw it down to 0 with the BDTD set to extreme and my right foot planted.
TxDiesel007
Jun 25, 2006 02:12 PM
tonyroberts
Mar 27, 2005 07:40 PM
dodgediesel4x4
Oct 16, 2004 09:14 PM
hellotbone
Jul 5, 2003 07:56 PM
DeaconWayne
Mar 28, 2003 06:06 PM
