4" exhaust Clearance Concern
Old Mar 26, 2005 | 03:33 PM
tonyroberts's Avatar
Question 4" exhaust Clearance Concern
Having recently installed a 4" exhaust on my truck I have a small concern.
There is a transmission line under the turbo that is close to the exhaust. I have tried to bend the line out of the way, but could only move it to within 1/4".
Is this enough clearance? Is there some kind of heat shield available? Is this a normal condition? Should I wrap the line in some sort of heat tape?
Sorry about all the questions, but, I am at a loss.
Thanks
Tony
1998 4x4 extended cab short bed
Old Mar 26, 2005 | 07:45 PM
masonic-dodge's Avatar
1/4" is fine, but some header tape on the down-pipe and the tranny line will help.
CRIS
Old Mar 26, 2005 | 09:27 PM
SjLingenfelter's Avatar
Are you saying the line is only 1/4" away from the pipe?
Old Mar 27, 2005 | 07:40 PM
kd460's Avatar
Sounds like the line that goes to the heat exchanger? Is it the section of line that is rubber (the part that has the anti drain back).
I would do something. Header wrap sounds like a good idea. Thanks for the heads up. I will be doing a 4 inch system soon. Will pick up some insulation as well.
Have others noticed this problem/conern? Thanks, Kevin
Johnsoncattle
Jul 3, 2011 11:49 AM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
nfsommer
Jul 31, 2006 11:16 PM
Hemlockusa
Jan 28, 2006 07:07 AM
