Fluid Dampener
Old Jun 27, 2007 | 08:49 PM
blownsmoke2's Avatar
Fluid Dampener
Well what due you guys think about fluid dampeners? Since my motor is at the machine shop being balanced would this benefit me or is it a waste of money with a balanced motor?
Old Jun 27, 2007 | 08:59 PM
demon1's Avatar
i love my fluid damper. i think that everyone should get one if they plan on running higher RPM. i just like having the piece of mind.
Old Jun 27, 2007 | 10:10 PM
Olee Poole's Avatar
A good upgrade for guys running Billet front cover TC or Dual Disc set ups.
Old Jun 27, 2007 | 11:32 PM
jwb600's Avatar
everyone I know that has one says they work great. they say they take alot of vibration out. I would like to try one out. the money tree stopped dropping 400 a wack
Old Jun 28, 2007 | 01:22 AM
Oh, I agree with you all just didn't know how much difference it would make with a balanced motor though. Were balancing everything from crank to piston rings.
Old Jun 28, 2007 | 01:34 AM
jwb600's Avatar
you must be pretty serious about winning something. should run really well now. who is doing your work? if you dont want to post it I understand.
Old Jun 28, 2007 | 02:00 AM
jmccart's Avatar
In a few weeks I will install the DD sprung clutch I bought. If it is really noisy/rattly, I might buy one. I have read a few threads where guys say a Fluidamper really quiets a DD clutch.
Old Jun 28, 2007 | 06:40 AM
Olee Poole's Avatar
They work great with the DD the Fluidampr helps with the added weight of the DD.
Old Aug 4, 2007 | 03:59 PM
I have been told now that if you have a fluid dampener you almost have to take it off to change the belt. Is this true?
Old Aug 4, 2007 | 08:43 PM
Timinva's Avatar
DTR Advertiser
On a 3rd gen you will have to remove the fluid Damper to change the belt. It is a real tight fit. Tim
Old Aug 4, 2007 | 10:28 PM
PourinDiesel's Avatar
Yeah but belts dont break on a regular basis (knock on wood!).
For any built motor Fluidampr is a must. Not only does it reduce vibration but it wont seperate into 2 pieces like a stock unit can.
The stock dampers dont like 4k rpm's and become dangerous up there.
Even with a balanced motor your still going to have torsional vibrations from the combustion events (basically when the engine is running).
Old Aug 4, 2007 | 11:17 PM
morkable's Avatar
I recommend fluid dampner to everyone I talk to
Kevin
Old Aug 4, 2007 | 11:27 PM
Olee Poole's Avatar
I have a few picture on here of a broke stocker and the fluidampr.
dodgediesel
Feb 19, 2007 11:05 PM
Agades
13
Jan 4, 2006 04:02 PM
Bobcat698
17
Nov 9, 2005 09:11 AM
HOHN
Dec 22, 2004 04:53 AM
Fishbait
May 18, 2004 09:39 AM
