Fluid Dampener, What's Your Thoughts???
Old Feb 19, 2007 | 02:16 PM
dodgediesel's Avatar
Thumbs up Fluid Dampener, What's Your Thoughts???
Anyone running one. A few guys were saying they are well worth the $450.00!!! Any comments?
Old Feb 19, 2007 | 03:04 PM
Jfaulkner's Avatar
Muted User
I've got one. IMO I'm not sure it would be worth $450.00. (I got mine free so that sort of made up my mind on getting it ) I'm sure it helps smooth things out but I was hoping for a little more transmission noise reduction. I have a G56 trans with a dual disk clutch and it gets pretty noisy at idle with the pedal out. After removing the stock balancer I did notice the rubber is coming out of it so I guess I was going to have to replace it anyway and I wouldn't buy another stock one.
Old Feb 19, 2007 | 04:18 PM
I was wondering if it was worth the $$$...
Old Feb 19, 2007 | 04:27 PM
qwest's Avatar
Would it make any difference to the life of the nv5600, make it any
quitter??
Old Feb 19, 2007 | 04:34 PM
98.5POS's Avatar
Well worth the money when you consider the harmful harmonics that it reduces in your engine. A lot of what it does you can't see or hear, but it's doing a lot!!
Old Feb 19, 2007 | 04:37 PM
Worth every penny then?
Old Feb 19, 2007 | 05:14 PM
Gallagher's Avatar
Ive got one. It will smooth things out alot. Harmonics play havoc on long push rod motors. I dont think it will net you a bunch of hp, but if you plan on going for big power this is one thing youl need for a very smooth drivable power.
Old Feb 19, 2007 | 06:12 PM
Jfaulkner's Avatar
Muted User
Like I said, I know it has to smooth things out otherwise they wouldn't use liquid dampers on every semi engine made. I'm just disapointed it didn't do more to help with the noise which is what I mainly wanted it for. Most people on here have a hard time spending that kind of money on somthing that doesn't add HP or don't see a immediate improvement in performance, milage or looks (not that Fluidamper ever claimed any of the above.)
Old Feb 19, 2007 | 06:57 PM
wildmanben's Avatar
I got one and the truck is way smoother than it used to be. Well worth it...
Old Feb 19, 2007 | 09:41 PM
12valve's Avatar
Does it add power? i thought i read something like that...
anyway it being in the list of mods to make 600 HP
Old Feb 19, 2007 | 09:54 PM
Ph4tty's Avatar
Fluidamper does claim a small increase in power, but I have my doubts. It helped cut down the tranny hum in 1/2 and smoothed out the engine overall. I think this is mostly for those running dual disk clutches or guys who want higher revs
Old Feb 19, 2007 | 09:57 PM
Does anyone know of the cheapest place to purchase one???
Old Feb 19, 2007 | 10:30 PM
Tate's Avatar
Did it eliminate/greatly reduce the vibration at 1700 rpm with the dual disc? Thats been driving me nuts, but the damper hasn't been at the top of my list to buy.
Old Feb 19, 2007 | 11:02 PM
PourinDiesel's Avatar
If you have a manual and get transmission vibrations from lugging gear or whatever the Fluidampr will greatly reduce those vibes.
I have one and it works great.
Old Feb 19, 2007 | 11:05 PM
Ph4tty's Avatar
Thats the tranny hum I was referring to. Cut the noise in 1/2 if not more.
bigjohn92
Aug 21, 2012 04:45 PM
blownsmoke2
Aug 4, 2007 11:27 PM
Agades
13
Jan 4, 2006 04:02 PM
Bobcat698
17
Nov 9, 2005 09:11 AM
Fishbait
May 18, 2004 09:39 AM
