Where to find lbs per minute for a turbo?
Old 08-07-2008, 08:58 PM
wap
wap's Avatar
I have been lookin at differant turbos recently and it is frustraiting cause some list cfm, some list lbs per minute and others still have a differant way to list it.
My question is where can I find how many pounds per minute does an S300 based turbo flow? Like a 62/71/13, or a 64/71/13, and I would also like to know how many pounds per minute my SPS 66 will flow.
Thanks for any help
Old 08-08-2008, 02:20 PM
zuki_dan's Avatar
The only person I know of that can answer your questions is Nathan at MPI.
http://www.maximizedperformanceinc.com/
Old 08-08-2008, 02:31 PM
enafzige's Avatar
May not help much for what you're after, but here are the specs on a few...
Turbo______CFM______Racing HP____Daily HP
HX35______600________420_________330
HX40______800________560_________440
T66_______800________560 _________440
B1________900________630_________495
H2E_______1000_______700_________550
HX50______1000_______700_________550
HX55______1050_______735_________578
HT3B______1100_______770_________605
T76_______1350_______945 _________743
HT60______1400_______980_________770
B2________1500_______1050________825
HX60______1550_______1085________853
T88_____1450-1750__1015-1225____798-963
HT4B______1800_______1260________990
Big Brother_1900_______1330________1045
T91_______2000_______1400________1100
HC5A/HX82_2450_______1715________1348
T100______2600_______1820________1430
T105______2900_______2030________1595
--Eric
Old 08-08-2008, 05:22 PM
wap
wap's Avatar
--Eric
Thanks man, I have been lookin for that but couldnt find it.
I could call Nathan but I know it will be a month or 2 at least before I can get twins, so I dont want to call and bother him for ever and not buy anything. I know he wouldnt mind, its just that I first hand how that is.
Old 08-08-2008, 09:49 PM
HOHN's Avatar
Thanks for any help
YOu need a compressor map.
S300-based turbos should have maps similar to the ones shown here:
http://www.bullseyepower.com/S300.asp
jh
Old 08-09-2008, 12:09 AM
Matt S's Avatar
How would you convert a compressor map to CFM's?
Old 08-09-2008, 12:39 AM
HOHN's Avatar
Density of air: .076lb/cu ft
jh
Old 08-09-2008, 06:57 AM
wap
wap's Avatar
Yeah compressor maps would be nice. I stinks that all turbo manufacturers dont use the same yard stick to measure turbos with.
I realize cfm can be vague, as can the normal sizing, ie 62/65/13 cause there are more factors to what a turbo will flow other than just the size of the wheels. But it would be nice to be able to make an apples to apples comparison with all the turbos out there.
Old 08-10-2008, 09:18 AM
Green04HO's Avatar
http://www.squirrelpf.com/turbocalc/map.php
Big Blue24
31
03-16-2008 08:31 PM
Great_big_juan
10-01-2007 01:01 PM
walexa
09-07-2005 11:40 PM
Quick Reply: Where to find lbs per minute for a turbo?
