Where to find lbs per minute for a turbo?
I have been lookin at differant turbos recently and it is frustraiting cause some list cfm, some list lbs per minute and others still have a differant way to list it.
My question is where can I find how many pounds per minute does an S300 based turbo flow? Like a 62/71/13, or a 64/71/13, and I would also like to know how many pounds per minute my SPS 66 will flow. Thanks for any help |
The only person I know of that can answer your questions is Nathan at MPI.
http://www.maximizedperformanceinc.com/ |
May not help much for what you're after, but here are the specs on a few...
Turbo______CFM______Racing HP____Daily HP HX35______600________420_________330 HX40______800________560_________440 T66_______800________560 _________440 B1________900________630_________495 H2E_______1000_______700_________550 HX50______1000_______700_________550 HX55______1050_______735_________578 HT3B______1100_______770_________605 T76_______1350_______945 _________743 HT60______1400_______980_________770 B2________1500_______1050________825 HX60______1550_______1085________853 T88_____1450-1750__1015-1225____798-963 HT4B______1800_______1260________990 Big Brother_1900_______1330________1045 T91_______2000_______1400________1100 HC5A/HX82_2450_______1715________1348 T100______2600_______1820________1430 T105______2900_______2030________1595 --Eric |
Originally Posted by enafzige
(Post 2171413)
Turbo______CFM______Racing HP____Daily HP HX35______600________420_________330 HX40______800________560_________440 T66_______800________560 _________440 B1________900________630_________495 H2E_______1000_______700_________550 HX50______1000_______700_________550 HX55______1050_______735_________578 HT3B______1100_______770_________605 T76_______1350_______945 _________743 HT60______1400_______980_________770 B2________1500_______1050________825 HX60______1550_______1085________853 T88_____1450-1750__1015-1225____798-963 HT4B______1800_______1260________990 Big Brother_1900_______1330________1045 T91_______2000_______1400________1100 HC5A/HX82_2450_______1715________1348 T100______2600_______1820________1430 T105______2900_______2030________1595 --Eric Thanks man, I have been lookin for that but couldnt find it. I could call Nathan but I know it will be a month or 2 at least before I can get twins, so I dont want to call and bother him for ever and not buy anything. I know he wouldnt mind, its just that I first hand how that is. |
Originally Posted by wap
(Post 2170792)
My question is where can I find how many pounds per minute does an S300 based turbo flow? Like a 62/71/13, or a 64/71/13, and I would also like to know how many pounds per minute my SPS 66 will flow. Thanks for any help S300-based turbos should have maps similar to the ones shown here: http://www.bullseyepower.com/S300.asp jh |
Originally Posted by HOHN
(Post 2171742)
YOu need a compressor map.
Density of air: .076lb/cu ft
jh |
Yeah compressor maps would be nice. I stinks that all turbo manufacturers dont use the same yard stick to measure turbos with.
I realize cfm can be vague, as can the normal sizing, ie 62/65/13 cause there are more factors to what a turbo will flow other than just the size of the wheels. But it would be nice to be able to make an apples to apples comparison with all the turbos out there. |
