FCA - Fuel Control Actuator Replacement.
Old 09-03-2009, 07:45 AM
Hummin Cummins's Avatar
Question FCA - Fuel Control Actuator Replacement.
Was looking at the FCA last night...
...all I need is to remove the two bolts and wire connector, then install the new one correct?
...no fancy tricks?
(the little ball bearing that can be seen from the top has me concerned as to what to do with it and what it does and if it impacts removal and installation)
Ron.
Old 09-03-2009, 08:06 AM
MikeyB's Avatar
The FCA looks like this. http://www.o-f-i.com/more/1958.jpg
There is nothing else to remove when replacing the FCA. IIRC there is three bolts holding the FCA.
MikeyB
Old 09-03-2009, 08:12 AM
Question
ANy hints on how to remove the 'three stubborn bolts'?
(been reading other threads but no suggestions)
Old 09-03-2009, 08:27 AM
rip 112's Avatar
Start shooting penetrating spray in em immediately and be prepeared for a hard time, as in don't strip the heads out on the first shot. Once you bust them loose its smooth sailing from there.
Old 09-03-2009, 09:01 AM
MikeyB's Avatar
Like Rick mentioned, a little shot of penetration oil. Also helps if you shock the screws with a brass drift and a hammer (lightly).
Also make sure you lube the new o-rings very well before installing. I damaged one and finding a replacement o-ring is a PITA.
MikeyB
Old 09-03-2009, 11:31 AM
Administrator/Jarhead
madhat's Avatar
Yeah, I tapped the bolts on mine. I used a piece of flat bar and came through the top for the two top bolts.
Old 09-14-2009, 01:42 PM
diesel8's Avatar
Fuel Control Actuator Image And Cummins Part Number
FUEL CONTROL ACTUATOR & BARRING TOOL IMAGES AND CUMMINS PART NUMBERS IN CASE YOU NEED IT. 03 DODGE 2500 5.9 check pictures here:
Old 09-14-2009, 03:28 PM
zuki_dan's Avatar
Make sure to use a high quality torx bit or it will mess up the screws! Don't ask me how I know.
Landini1
12-15-2009 01:17 PM
Roperteacher
13
09-21-2008 10:44 AM
cabeen95
01-18-2008 11:53 AM
draskobnsf
17
05-29-2007 08:29 PM
N.Johnson
10-20-2005 09:38 AM
Quick Reply: FCA - Fuel Control Actuator Replacement.
