Engine shuts off and engine light is on
Old 12-17-2004, 04:12 PM
Stevenc's Avatar
On the way home just got off the highway and the engine dies. Nothing rough or anything, put in neutral and it starts back up. Engine light is on also. Anyone experience this before or can guess what it can be. Called dealer and they said to bring by in the morning.
Also, noticed the steering box has grease residue on it. PS did seem to be low, is this a known problem?
Old 12-18-2004, 07:39 AM
Blue600's Avatar
Cycle the ignition 3 times and you should get a "P" code on the odometer.
Old 12-18-2004, 10:45 AM
rementa's Avatar
that happened to me about 2 weeks ago. the engine just died turning in to my drive way. it started right up. 4 days later i took my son to school and on the way home it died. i forgoy my cell phone at home, i ended up walking 5 1/2 miles home. problem was the lift pump. they go out with out any warning. some go out with 20,000 miles some with 100,000 miles my went out with 51000 miles. it's under warrenty. mite take 2 days or a week to fix part has to come from mich. good luck
Old 12-18-2004, 04:43 PM
moterhead's Avatar
My '04 started doing that in conjunction with a loud clattering at idle. Got it in to a dealer (visiting the in-laws). Bad injector. It was gunked up with some kind of slimy black stuff. The tech showed it to me. This was in Michigan. The part had to come from Indiana, I think.
Old 12-19-2004, 01:42 AM
SHINDEN's Avatar
Stalling.
It happened twice to me, both times comp. said injector pump, now I have new injector pump, engine is much smoother and more responsive, dont know about milage yet.
Regards Jack.
Old 12-19-2004, 07:05 AM
kry226's Avatar
Did the dealer cover it under warranty? It seems they had an avenue to pin it back on you for crappy fuel. Wouldn't surprise me.
Old 12-19-2004, 07:41 AM
moterhead's Avatar
No, they didn't even try to wiggle out of warrantying it. And I was from "Out of Town". In Ann Arbor, Michigan, from Florida (at the time). Did a nice job on it, even washed and vacuumed the truck. Suggested running some fuel additive thru it for a few tanks to clean out anything left from what was obviously a dirty batch of diesel.
Old 12-21-2004, 08:34 AM
Stevenc's Avatar
Service guy called and said truck will be ready today. Said lift pump was bad, is this the same as the injector pump?
Also, replacing the seal for the steering box, this was the reason for the leak.
I will have more info after I get the truck back.
Old 12-21-2004, 08:48 AM
moterhead's Avatar
No, lift pump and injector pump are not the same. The lift pump, also known as transfer pump, is the low pressure pump that pulls the fuel from the tank. The injector pump is the high pressure pump. Mucho difference in price and work involved to change.
On 2nd gen trucks, a lift pump failure was often followed by an injector pump failure. Injector pump is cooled and lubed by the fuel passing thru it. Lift failure starves the injector pump. I had a lift pump failure on my 98.5. It was on a trip from the Keys to Michigan for Christmas. From the time of calling the wrecker til we were back on the road was three hours. Not a bad breakdown, especially since it was warranteed. Part of the EPA mandated emission system warranty.
Old 12-21-2004, 01:18 PM
Stevenc's Avatar
Talked with another service guy and he did say it was injector pump, not lifter pump like the other dope said. I did notice that it seem kinda sluggish, so hopefully this will help. Also had 3 injectors replaced about 3 months ago. Wonder if I should get fuel some place else from now on?
Old 12-28-2004, 08:29 PM
Stevenc's Avatar
Finally got the truck back today!! They never could give me a great answer as to why it took so long. It was the injector pump (pn:R5104877-AA) cost was over $1k just for that part. Also had a leaking steering box and they replaced with new one (pn:52106835-AE). All was covered under warranty, have 19k miles on truck. Also the rental car was almost $500 for 10 days and my Max Care Ext warranty (Dodge) covered that.
Hopefully no more problems, think I'll be getting fuel from another gas station from now on!
BroncoAZ
09-26-2009 10:01 PM
DmaxEter
09-11-2006 06:06 PM
2500Ram
07-11-2005 10:53 PM
popeyesides
09-12-2004 03:05 AM
TheMoose
10-31-2003 12:06 PM
Quick Reply: Engine shuts off and engine light is on
