Edge Comp Problems
Old 05-23-2005, 11:36 AM
Desert Diesel's Avatar
Edge Comp Problems
Cross Posted from another thread in the "Other" forum:
Originally posted by joefarmer
Hohn/jlh/Justin,
I purchaced an Edge Comp off these forums that didn't live up to it's 'Drag' label (not the buyer's fault at all, only a dyno figured out the difference). Edge replaced it completely, harness and everything, since it was still in the full replacement warrenty period (1yr). Get the buyer to contact Edge. Keep in mind Edge failure rates for 24v boxes after 2-3 years are somewhere in the 95% range. They made it right for me and should for your buyer.
brandon.
95% EEK!
My box is ver 7.0, made 7-31-2002 and just 2 months ago it started acting up. First I thought it was a power supply issue because it would shut off at random, then it began to "Lock up and become unresponsive". Now it's causing enough havic that I removed it altogether and called for an RMA.
Any idea how it tends to go from here? Should I get the lube out, or are they going to treat me well?
Old 05-23-2005, 12:29 PM
joefarmer's Avatar
Keep in mind that was a quote from one un-named vendor, not every vendor. I've heard they know Chinese QC sucks and should be fairly responsive.
brnaond.
13jy831
02-25-2011 07:45 AM
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
Quick Reply: Edge Comp Problems
