Edge Comp Problems
Old May 23, 2005 | 11:36 AM
Desert Diesel's Avatar
Edge Comp Problems
Cross Posted from another thread in the "Other" forum:
Originally posted by joefarmer
Hohn/jlh/Justin,
I purchaced an Edge Comp off these forums that didn't live up to it's 'Drag' label (not the buyer's fault at all, only a dyno figured out the difference). Edge replaced it completely, harness and everything, since it was still in the full replacement warrenty period (1yr). Get the buyer to contact Edge. Keep in mind Edge failure rates for 24v boxes after 2-3 years are somewhere in the 95% range. They made it right for me and should for your buyer.
brandon.
95% EEK!
My box is ver 7.0, made 7-31-2002 and just 2 months ago it started acting up. First I thought it was a power supply issue because it would shut off at random, then it began to "Lock up and become unresponsive". Now it's causing enough havic that I removed it altogether and called for an RMA.
Any idea how it tends to go from here? Should I get the lube out, or are they going to treat me well?
Old May 23, 2005 | 12:29 PM
joefarmer's Avatar
Keep in mind that was a quote from one un-named vendor, not every vendor. I've heard they know Chinese QC sucks and should be fairly responsive.
brnaond.
lvmknsmoke..
Nov 21, 2024 07:33 PM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
