Eaton HO72
Old Jul 15, 2009 | 11:07 AM
BAR's Avatar
BAR
Eaton HO72
So the dana 70 in the back of my truck has been giving me problems lately, I cant get the pinion seal to stop leaking, and it is starting to make funny noises. I was thinking of changing it out with a 14 bolt or dana 80 but happend to run across a HO72 for sale in my area. A few questions, can I put 4.10 gears in it? It has 5.13 gears in it now, that he welded, I think it came out of his mud truck. I looked a little online for ring and pinion sets for it but couldnt find any, seems like parts are kind of hard to come by. I read that some 14 bolt parts are interchangable with the HO72 but I dont want to buy it and have it turn into something that I cant use or is going to cost me an arm and a leg to get under the truck. Also he want $400 for it, what do you think of that price?
Old Jul 15, 2009 | 11:16 AM
apwatson50's Avatar
Been done:
https://www.dieseltruckresource.com/...e-t242590.html
Old Jul 16, 2009 | 05:22 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
400$ is way to much for an HO72
You could probly find one in a bone yard for 100$ or so with 4.11 in it already
Old Jul 16, 2009 | 05:51 PM
Cowboy_Customs's Avatar
kind of off topic, but not quite. Never heard of that rear end, what the heck is it out of??
Old Jul 16, 2009 | 06:55 PM
49-72 GM 3/4 and 1 ton trucks and vans. Its a heck of a stout rear ,Alot of pullers in this area are using it
Old Jul 16, 2009 | 07:13 PM
BAR's Avatar
BAR
Thanks for the reply. I kind of figured that was too much money, I guess I will start looking in local junkyards. Does anybody make a limited slip for these, or is it a detroit locker or nothin? How can I tell what gears are in it, will there be a tag on the axle or do I need to count R&P teeth?
Old Jul 16, 2009 | 08:22 PM
Detroit or nothing, I actually have a Factory Detroit under my old 67 but its stayin there, there hard to find
There might be a tag, maybe, or you could look at the option sheet(Should be inside the glovebox) if its still there and if the rear hasn't been changed over the years, but the best way is yes pull the cover and count and divide. IIRC there might be a stamping in the ring that tells your tooth count also
Old Jul 16, 2009 | 09:36 PM
BAR's Avatar
BAR
Anybody ever run a detroit in a daily driven truck? Obviously the axle could take it, just worried about tire wear. Eventually I would like to build my truck so I could hit up a few local truck pulls here and there and not have to worry about breaking parts every time, since I drive my truck everyday. Thats what first got me interested in the HO72, it looks pretty stout.
Old Jul 16, 2009 | 09:40 PM
93flatbed's Avatar
Not that bad to deal with. You will have to get used to driving it though. ("Click click boom!") Tire wear isn't too bad for me. I guess it would all depend on where you drive, high way or lots of turns on city streets?
Hope any of that helps!
Justin
Old Jul 16, 2009 | 10:09 PM
I ran the one in my 67 for 6 years daily, just let off when you go around corners and tire wear should be minimal. The Detroits are noisy though
Old Jul 17, 2009 | 08:11 AM
I second the "click click BOOM" of a Detroit. My best friend had one in his rear end, the first time I ever rode in his truck, I thought we exploded the rear going around a corner. But it was just the Detroit releasing.
Old Jul 17, 2009 | 06:02 PM
That's the key. Coast through turns and they are much less obnoxious.
Old Jul 18, 2009 | 12:57 PM
BAR's Avatar
BAR
Well I went to a local junkyard yesterday and found two HO72's. One had a factory detroit in it but he would only sell it as a pair with the front axle on the truck and wanted $750 for the both. The second one was just laying in a pile of junk and he said he would let it go for around $100. I pulled the rear cover and the inside looked good. I counted 32 teeth on the ring gear, so can someone help me figure out what gear ratio that converts to.
nfsommer
Mar 26, 2007 12:18 PM
Dan Marino
20
Aug 23, 2006 09:41 PM
Mglass1045
0
Jun 17, 2006 08:40 PM
WSnyder
0
May 22, 2006 01:59 PM
Nicholas
Dec 29, 2002 07:17 PM
