rear brake drums part number
Old Jul 17, 2009 | 12:20 PM
dheffel's Avatar
Looking online for replacement rear drums and there are soo many options. My drums are to thin to turn and the shop wanter $700 for new drums pads and wheel seals. I can do the job and I will get the parts but I want to go to the 3in pads with larger cylinders. anyone know the drum part numbers. I will use ther wc36057/58 cylinders with 314pg pads but i dont know what drums to get. Thanks. '93 w250
Old Jul 17, 2009 | 12:22 PM
oilcan64's Avatar
700 for drums!!!! holy smokes
let me know what you find, i plan on doing mine too
Old Jul 17, 2009 | 03:00 PM
dheffel's Avatar
I was looking at the raybestos 1961r drums. they have a 14 in outside and 6.29 total depth which seems right. Does anybody know if this will work for the one tone upgrade?
Old Jul 17, 2009 | 05:50 PM
Those are the ones you want for either size shoes.
Old Jul 17, 2009 | 06:48 PM
dheffel's Avatar
Thumbs up
Thanks wanna. I couldn't get a straight answer from any parts places. This site is a God send.
Old Jul 17, 2009 | 07:49 PM
12valve@heart's Avatar
Are you going with the Dodge 1-ton wheel cylinders or the larger GM 1-ton wheel cylinders? If you want maximum rear stopping power, go for the GM units. The only modification required is to re-bend the rear brake line so that it screws in straight instead of at an angle like the Dodge units.
Also, don't forget to rebuild or replace the self-adjusters on the rear. Nothing worse than having to crawl under and readjust them manually every few thousand miles (ask me how I know) after putting on new drums and shoes.
Old Jul 17, 2009 | 08:17 PM
And don't forget to paint every little peice and part in that rear brake system, to scare away RUST. every spring, bolt, clip etc. etc.
Old Jul 18, 2009 | 09:01 AM
SkinnyBTN's Avatar
If you can weld or know someone who can and will you could purchase the weld on rear disc brake brackets and purchase all the parts required for rear disc brakes for $300. It took me an afternoon to weld the brackets and install the brakes. It was absolutely the best upgrade I have made to the truck.
Old Jul 18, 2009 | 01:01 PM
dheffel's Avatar
I thought about the disk brake conversion but figured the larger shoes and one tone cylinders would be enough. I think I will probably get the chevy wheel cylinders too. thanks again everyone.
loudhornsrule
Aug 5, 2014 03:12 AM
Diesel_Power_2
Dec 7, 2012 10:02 AM
ollieman
Sep 7, 2010 12:38 AM
Dean Snow
Dec 14, 2007 11:49 PM
Pete Miller
15
Dec 17, 2005 01:16 AM
