Guess that axle(1st gen axle upgrade)
Check out what stillsmokin and me are workin on, can you guess what axle it is?
These have been used in gas pull trucks in our area for quite a while with a lot of good results in stock form, This one has been altered quite a bit using parts from another common rear
MMMM Beefy
MMMM Beefy
i wanna say its a ferd 9" but i've never seen one with a removable cover or floating axles. plus the pumpkin looks a little off.
did you jig the axle so as not to warp the tubes when you welded it?
No aluminum, all Iron and steel
I'm not sure on weight, but this axle has a lot of advantages over the 70 and even the 80, 2" pinion, 3pinion bearings, pinion support, and a load bolt to resist ring gear deflection
GM, Medium Duty, found under 19,500 - 24,000 GVW trucks, most common ratio 6.17 : 1. An early version was used in the GMC M Series Military 2-1/2 Ton 6x6 starting in 1952. EDIT: First thought was Eaton was used in the 6x6 but my TM shows it as manufactured by GM.
I see those all the time under older GM trucks; in fact, I have a 1964 GMC ton-and-a-half that I believe has that same rear-end.
How did you address the difference in bolt-patterns ?? Mine is old-style ten-hole.
Not to mention seperate/removable pinion housing and removable carrier.
The reason rears are built like they are today is not because they are better, but because they are much cheaper.
You guys are gettin real close
This axle started life under a 67 chevy C20, It is an HO72 but now its a hybrid axle using a bunch of 14bolt internals like the mini spool, axle shafts and som other stuff
Trebor and Bearkiller the axle you are thinkin about is the HO72's big brother the HO110, stillsmokin and me have a few ideas about using that axle also
Thanks for the info.
I like to see out-of-the-box thinking that is obviously an improvement over stock.
Show us more.
