DSS Install Question
Old 05-29-2008, 06:15 AM
01RAMer's Avatar
I've installed the DSS and regardless of what I tried, couldn't get the nut centered in the frame hole. Putting on the bearing, the bolt holes were off by about 3/8 of an inch towards the passenger side.
Anybody else have this problem and what did you do to correct it?
Old 05-29-2008, 07:00 PM
rotohead's Avatar
Try loosening the bolts to the frame as much as possible w/o the bearing, don't freak out about where the nut extention sits in the whole. Nice and loose-sloppy. Then bolt up the bearing over the nut extention loosely too. Start snugging down the bolts to the frame first and see if things align. I know what you're talking about and thought I would never get it installed. AND my install included a front reciever hitch. Longer bolts were needed but I got it all installed ovr a couple years now. The bearing is self centering and I just watch how the grease purges around the bearing to verify it's centered. Love my DSS.
Chuck
Old 05-29-2008, 09:12 PM
wcbcruzer's Avatar
Make sure your wheels are straight and you parked on flat ground when doing the install. Your frame could be a little bent causing the holes not to line up. I had a similar problem when I installed mine but I realized it was because I was parked in our downward driveway kind of sideways and had my wheels turned to the right. But I called PSC first and the guy told me he's seen a few trucks with a little bent frame since these engines are so heavy and it's hard on the steering box. Overall, just try to get it on. If it's off by a little bit maybe you can still tighten it down.
caper
05-08-2005 11:08 PM
caper
04-22-2005 10:55 PM
chasmack
03-21-2005 05:35 PM
Turbo Deeezle
01-24-2005 08:41 PM
Sidewinder
0
07-06-2004 09:15 PM
Quick Reply: DSS Install Question
