Drain Plug For Oil Pan
Old Apr 28, 2004 | 12:39 PM
Sonny's Avatar
Hello, I was going to order a new oil drain plug that is EASY to to oil changes. What is the best to use? Thanks
Old Apr 28, 2004 | 01:02 PM
dodgediesel4x4's Avatar
This one fron geno's should work fine for your rig.
http://216.167.41.9/CoastalData/show...D=1012&CATID=1
Old Apr 28, 2004 | 03:11 PM
BIG&BAD's Avatar
thats the same as i got on my truck
works good, as far as not opening when im 4wheelin
i havent changed my oil yet so i dont know how it drains
Old Apr 28, 2004 | 07:08 PM
infidel's Avatar
People have reported that the finger touch drain valve leaves about half a quart in the pan when you drain due to the threads extending up into the pan. The oil/sludge down at the bottom is what you want to remove the most.
People have overcome this by cross drilling holes about a 1/4'' up from the seal into the threads. These holes must match up with the grooves in the female threads of the oil pan when the valve is tightened up. Not sure if other drain valves have this same problem but would imagine they do.
For me the stock plug works just fine, over 60 changes, still on the original washer.
Trick is to never use the recommended torque on one, just snug it up tight, about 25 ft/lbs.
Old Apr 28, 2004 | 09:23 PM
Dr. Evil's Avatar
I have the FEMCO EZ Drain:
http://216.167.41.9/CoastalData/show...ID=210&CATID=1
Makes chaining oil a whole lot less painful and messy. I actually measured the amount of oil left in the pan and it was around a 1/4 litre.
Old Apr 29, 2004 | 03:24 AM
Robert Rausch's Avatar
I like the stock drain plug too. I just dont take it out all the way when I drain oil.
I have about 20 changes on it and I don't torque it too much either.
Question for Infidel... Bill, do you ever try to get that last 1/2 inch of oil out of the stock pan w/ stock plug? I tried once with a bent piece of copper tube hooked to a Turkey Baster, but it didn't work too well.
Old Apr 29, 2004 | 06:12 AM
Commatoze's Avatar
I've used both, and I prefer the Femco EZ-Drain.
Old Apr 29, 2004 | 09:42 AM
infidel's Avatar
Robert, I didn't think much was left in the pan with the stock plug, but have never checked.
Old Apr 29, 2004 | 11:48 AM
Sonny's Avatar
Thanks for the replies everyone!. I like the EZ-drain plug.
smokinram99
Jul 28, 2009 10:07 PM
mstep3
Jun 29, 2009 03:15 PM
Mechanos
19
Jan 31, 2006 10:08 PM
DMOBBERLEY
Jan 8, 2006 04:38 PM
03CTDCO
Jun 15, 2005 11:11 AM
